Using TrueRta to adjust subwoofer delay
  • kgveteran
    • 865
    How would I adjust the delay for my subs on my processor to match the mains of my HT ? There has been talk of this on other forums.
    Most of the talk is that there is a problem with the subwoofer delay and that the numbers don't coinside.Your thoughts.
  • Clive
    Former Moderator
    • Jan 2002
    • 919
    Doesn't most processors adjust the delay time based on the distance inputted?
    CLIVE
    • kgveteran
      • 865
      Yes. I was wondering if RTA could assist with this process to make it more acurate.
      Or better yet can I use TruRta to check to see if the processors numbers are correct.
      • Azeke
        • Mar 2003
        • 2123
        I have the TrueRTA software, but have not used it for sub calibration. I would first, as Clive suggested, set my delays properly, and also calibrate your speakers including the sub. This should provide a good starting baseline. Then perhaps you could use the spectrum analyzer to fine tune and determine further information.
        Keep us posted on your progress.
        Best regards,
        Azeke
