Hmmm, cable opinions needed. Help me...I'm a HT noob.
  • cyberspyder
    • Apr 2008
    • 60
    Not sure which section to put this in....but it pertains to audio, so meh.
    I currently have the following: Pioneer DV-515 DVD player, a cheap ass Magnasonic player for those pirated DVDs, a HTPC, a Pioneer Laserdisc/VCD player, a VCR and a NEC AV-300PRO receiver. What I want to do is hook everything up to my TV...problem is this:
    What's this? Only two sets of component inputs? But I have 4 items that needs connecting (HTPC will be connected via VGA or HDMI)! The Pioneer and Magnasonic both support component, while the others only composite....would I need a switchbox for this? And depending on the HD box I get from Rogers...I may have to sacrifice another set of inputs, because only the highest end model supports HDMI...all others are component and analog.
    Past this issue, there's also the question of what cables to use. I've seen people recommending Blue Jeans Cables...are they that good? Based on my needs would this be ideal?
    -Belden 7787A Component Video Cable, 10 feet run (For connecting the HD box to the TV)
    -Belden 7787A Component Video Cable, 10 feet run (For connecting the TV to the switchbox)
    -Belden 7787A Component Video Cable, 1-2 feet runs (For connecting the switchbox to the DVD players)
    Here's a SNAFU:
    How would I connect the VCR and laserdisc player to the component inputs? They only have composite outputs. Would I have to route them up to the HD box, and then the HD box will stream it to the TV via. component?
    Past the video issues...there's also the receiver. Currently, it has the following jacks available:
    Good thing most of my gear is old by today's standards....Would I just hook up all the V/L/R outputs to it (including the L/R audio outs on the TV)?
    Is the Video connection necessary?
    Lastly...another SNAFU. Currently I'm using this receiver to power a set of Bose 2.1 *I GOT FOR FREE*...but obviously they suck. So I'm wondering if anyone has any luck in hooking up a subwoofer to the amp. The Bose Accoustimass ('sub') uses the left, center and front channel outputs on the amp, instead of a dedicated sub out...which I can't seem to find. Is there a sub amp/sub that offers the same sort of connection?
    That's it for now, Brendan
    • 27460
    There are simple switch boxes 1 to 4 probably component video. As to the other issues, I'm going to leave that to someone else at this point.
    Cable wise, BJC is basically belden grade stuff. How good is that, let the buyer decide. Yeah, the prices are probably ok. The next issue you have, is being in Canada, shipping not cheap on component due to weight usually, and you'll likely have to pay some duties. Maybe local cheap component sets is better idea for you...
    • Kevin P
      I've discovered the ultimate audiophile component
      by Kevin P
      In my years of stumbling around audio and HT-related forums, one thing I've noticed that many audiophiles seem to agree on are these things (note that this is for music, not home theater):
      • 2-channel is preferred over multi-channel
      • Vinyl is preferred over CD, and even SACD/DVD-A
      • Tubes are preferred
      19 March 2003, 15:21 Wednesday
    • SiliGoose
      3 Component ins? -I need your suggestions!
      by SiliGoose
      I've outgrown my H/K AVR-7000. I have 4 component video sources, the 7000 has only 2 component inputs. I have 6 digital audio sources while the 7000 only provides for 4 inputs.
      I'm currently using a cheap switchbox for the component inputs and manually swapping digital ins when necessary....
      20 March 2002, 12:48 Wednesday
    • Claude D D
      Belden 89259 DIY speaker cable
      by Claude D D
      I finnished building my first set of cross connected Belden 89259 speaker cables on Apr9.They took about 3 hrs to make and cost $125 CDN (approx $78 US).I had been using Kimber 8TC.Upon installing the new cables in place I immediatly noticed a more layered soundstage,more detail and tighter deeper bass...
      11 April 2003, 13:00 Friday
    • Preacherman
      Component Splitter
      by Preacherman
      Ok, I need some advice. I am thinking that I will be in need of a component splitter in the very near future have. As of now I have component from my HD Cable box, and also from my LG-7832 upconverting DVD player go to my Onkyo TXNR801-b receiver. The Onkyo has only 1 component out which I send to my...
      01 March 2006, 16:34 Wednesday
    • bcgator
      A/B speaker switching/switchbox?
      by bcgator
      Hi all,
      As some of you may have seen from previous posts over on the B&W speaker board, my 5.1 system consists of B&W 704's up front and 805's in the rear.
      As my quickie comparison review stated, I like the 704s for certain kinds of music (rock, pop) and the 805's...
      28 November 2004, 21:50 Sunday
