Audio switching in/out
  • mikegunnz
    • Jan 2007
    • 15
    Hey guys, I have a question regarding the audio when I watch tv. I've got a scientific atlanta through cablevision, yamaha receiver, hooked up to a panasonic plasma monitor. Periodically(3-4x a week) I'll be watching something on hdtv and the sound will cut out for a sec and the receiver will switch from dolby digital to pro logic. This happens more often with hdtv although it has happened a couple times while watching sd channels and receiver will cycle through like it switching throught different audio(prologic-digital-etc)
    It doesn't happen that often, but its a little annoying. I can't figure what the problem is. It only seems to happen when watching tv, not dvds or playing wii. Could it be the cable box?? Maybe the digital coax?
    Any suggestions would be appreciated.
  • Glen B
    • 1106
    You don't say how your audio is routed to the receiver. I have Cablevision HD service and they just drive me crazy sometimes with their different annoying quirks, like signal dropouts, boxes rebooting in the middle of watching a program, loss of advanced services, etc. I suspect that the cable audio signal is cutting out for a split second and the receiver is searching, trying to detect the type of signal (if your Yamaha works anything like my Onkyo receiver).
      Originally posted by Glen B
      (if your Yahaha...
      What's a "Yahaha"? Sounds funny.
      • mikegunnz
        • Jan 2007
        • 15
        its hooked up through digital coax. If others experience it too, then maybe its not my equipment and just the service. It only happened when watching tv so I figured it was either service, cablebox, or the digital coax from the box to the receiver.
        • mikegunnz
          • Jan 2007
          • 15
          oh and by the way I have a yahaha receiver. It's much better for comedies than other receivers.....makes jokes funnier. :P
            • 4157
            Ditto
            • Taito
              Preferred relay for switching audio sources?
              by Taito
              Hi, I'm working on the design of a preamplifier at the moment and would like to know if anyone has found some really good relays for switching audio sources, or has come up with a better way to do it -at this stage, the plan is to incorporate some form of microprocessor control (which I'm pretty sure...
              07 November 2005, 07:53 Monday
            • Lectoid
              Receiver or pre/pro and amp?
              by Lectoid
              I am currently working on building a B&W 60X S3 series based 5.1 system. At this time a 7.1 doesn't interest me. I have the 5, just need the .1 now.
              I have:
              * Samsung HL-T5087S LED DLP TV.
              * Toshiba HD-A30 HD-DVD player - HDMI to TV
              * Xbox 360 ...
              06 January 2008, 01:30 Sunday
            • paulct
              Use TV instead of Receiver for Switching?
              by paulct
              I've noticed that many of the new RPTV's have a host of inputs now, handling all the right stuff. My question is, given that I still want the audio to go through my Onkyo receiver for sound, which unit should switch between the components? Seems easier to hook the DVD, Cable Box, GameCube and Raw cable...
              17 August 2004, 13:58 Tuesday
            • bnieman
              HDMI Audio Ouput or Pass through from Receiver
              by bnieman
              I am planning on upgrading to the RSX-1560 but have a question regarding HDMI output on receivers.
              Is audio sent with the HDMI output on the receiver? If so is the audio the same as the source or does the receiver process the audio in any way (volume, surround processing,...
              05 December 2008, 10:44 Friday
            • dondon
              Separated amp and Receiver to improve audio sound quality
              by dondon
              Hi, I am new here. I would like to seek your kind advise on this.
              I have the HT set up with Marantz SR8500 receiver + B&W 704 front L/R, LCR600 center, ASW600 subwoofer and DM600 L/R rear. I play movie with Marantz DV6500 DVD player.
              I am pretty satisfied with the...
              12 July 2006, 01:21 Wednesday
