Hi guys, need a little assistance here. How can I install an additional subwoofer to my theater system, my receiver is a DENON 7.1, would I just use a Y-Adapter from the single sub out to make it two?
Using 2 subs
Tags: None
that works fineOriginally posted by at_sunset_blvdHi guys, need a little assistance here. How can I install an additional subwoofer to my theater system, my receiver is a DENON 7.1, would I just use a Y-Adapter from the single sub out to make it two?- Bottom
It's a 2802, I just check it right now & it only has 1 sub-out.Originally posted by AzekeThat is correct, and ensure you use a quality y adapter. However, I am unsure of your Denon Model, but you may want to check to see if you have a sub2 outlet. I use my sub2 outlet for my Buttkickers.
Peace and blessings,
Azeke
My Denon is a 3801 and only has one sub out so I use a Y adapter and it works just fine.- Bottom
Hi there Chris saw one of your reps in the 7.1 topics, saying your using tactile tranducers, what are these really for? I tot these gadgets are just inserted in the back of the chair cushions for extra shaking vibrations. Would these improve the lows a lot more or I'm right it just a novelty for extra vibrations on our backs? hehe (quite so primitive on these transducer stuffs)Originally posted by Chris DHi, and welcome! Yes, Y-adapters work just fine. I use one for my bedroom A/V setup.
I was born on Clark AB there, back in the day!
Tactile transducers/shakers are often mis-used, with the effect turned up to excessive levels, and yes, then it becomes a novelty where during low bass and explosion scenes your butt is shocked with massive vibrations. When used properly, though, it does augment the subwoofer, ENHANCING the sensation and experience. Do you need them? No, not if you've got a good subwoofer that can play low and move a lot of air in low frequencies. But it makes a movie more than just a visual and audio experience, it makes it a tactile sensation experience, too.
They are often used just for low bass, where they are most effective. But the best TT's, like Clark Synthesis, are actually capable of full-range reproduction, enhancing the whole audio range. For this reason, Clarks are used to help deaf people hear/experience movies and music. Also, yes, transducers/shakers can be used to augment a weak subwoofer, or give you still full bass experience if you need to keep the volume low, like if you're in an apartment.
- Pleasantville- Bottom
wow thats cool, could we install it by ourselves? does it need an amp to power it?Originally posted by Chris DTactile transducers/shakers are often mis-used, with the effect turned up to excessive levels, and yes, then it becomes a novelty where during low bass and explosion scenes your butt is shocked with massive vibrations. When used properly, though, it does augment the subwoofer, ENHANCING the sensation and experience. Do you need them? No, not if you've got a good subwoofer that can play low and move a lot of air in low frequencies. But it makes a movie more than just a visual and audio experience, it makes it a tactile sensation experience, too.
Yes (very easy to install) and Yes (separate amp is required).Originally posted by at_sunset_blvdwow thats cool, could we install it by ourselves? does it need an amp to power it?
FYI. I am certainly enjoying the buttkickers that I've installed. If you are considering this item, I would suggest the Buttkicker LFE kit (for around $400.00 with s&h on a 2 day arrival, MSRP $495.95). It comes with an amp, wiring (although the wiring is not to my standards), and chair mounting accessory. This kit is heavy it weighs around 40 lbs. I have enjoyed it so much that I bought another buttkicker and chair mount to evenly distribute the effects. I checked on some other transducers, but the BK provided the best bang for the buck (not to expensive, not to cheap).
AzekeLast edited by Azeke; 03 February 2007, 00:30 Saturday.- Bottom
by switheyIntro
I’m a long time AVSer and have recently discovered HTGuide and the “Mission Possible DIY” Thread. I’m in the process of building out my HT and wanted to have some serious bass in the room. My small to medium sized room is 14.5’ wide x 19.5’ long x 8’ vaulted to 10’ ceilings...-
Channel: Mission Possible DIY
by crxI've been lurking around for a couple of days - and this forum seems to be right place to get valuable insights and suggestions to my questions.
My brother-in-law is starting to build a new house in the next couple of weeks and he approached me to help him design a home theatre and multi... -
by Dennis HI don't get over to the $20K+ forum at AVS much so I had missed this one until now.
Way too long thread:
http://www.avsforum.com/avs-vb/showt...9&page=1&pp=30
More interesting blog showing the install:
http://bassment.wordpress.com/...-
by sikonikoIt seems there are some people having issues with getting the SSP-800 setup. It seems to me that we should create a category so people can find information easily instead of letting it get burried with other conversations.
Tip 1: Setup your first input to receive an audible signal...-
Channel: Club Classé
by len73Hello everyone !
I would like to know if some of this forum users already have had the opportunity to test the Monitor Audio RSW12 subwoofer and to get some feed-back about this sub.
The fact is that I am currently looking to replace my hole HT system. Most of the component...-
Channel: Audio Hideout
- Loading...
- No more items.
