Oppo speaker / surround settings
  • moe32274
    • 38
    I have an Oppo OPDV971H hooked up to a Rotel RSX-1057 using only an optical cable. I want to have the Rotel handle all audio processing. I set the appropriate crossover settings, surround sound settings, & etc. using the Rotel OSD.
    The SPDIF output on the Oppo is set to RAW.
    Under these circumstances, the values on the Oppo "speaker setup page" (i.e. the downmix mode and speaker size values) are not applicable, right??
    I just want to make certain I'm seeting this up correctly.
    Moe.
  • peterS
    • 1038
    ask thier customer support
    you will probably get a reply in an hour
    • Vinny
      • 252
      Moe.
      Those only applicable to the analog 5.1 signal for DVDA or DVD if you want that output
      otherwise it'll just go into the receiver without altering it
      Pioneer KRP-500M
      Emotiva UMC-1
      Parasound 5125
      Oppo BDP-83
      Klipsch RF-3II, RC-3II, RB-5II
      SVS PB-10NSD
      • wettou
        Oppo Bdp-93
        by wettou
        • Exceptional Picture and Sound Quality
        • 2nd Generation Qdeo Video Processing
        • Blu-ray 3D & Network Streaming
        • SACD & DVD-Audio/Video
        • Wireless N, eSATA & USB 2.0
        • Dual HDMI, IR & RS232 Control
        Coming Soon. Register to be notified of this product's release. Price: $
        10 November 2010, 16:37 Wednesday
      • boffo
        bass issues with RSP-1572 and Oppo UDP-205
        by boffo
        Hi, folks! I have a quick question:
        I use the Oppo's analogue outputs to feed the Multi inputs of the preamp/processor and it works great for most things. However, I find that I sometimes get far too much bass from movies in surround than I do from stereo audio. I've tweaked the M&K subwoofer,...
        20 June 2019, 11:46 Thursday
      • CabinetGuy
        Dual use of HDMI outputs on Oppo 95 to SSP 800
        by CabinetGuy
        I just purchased the Oppo 95 AND upgraded from the SSP 600 to the 800. I am in the process of setting them up. I am having difficulty understanding the best approach of what I think are two options to connect them for the BEST HDMI audio/video delivery and thus I am having trouble getting the sound/picture...
        07 May 2012, 22:27 Monday
      • madmac
        Review of the Oppo BDP-95
        by madmac
        A friend of mine bought the Oppo BDP-95 and popped it off at my house so I could try it out because I was really interested what this unit can and would do in regards to audio performance. It is touted as having some pretty heavy duty DAC technology!!. First off, the out of box experience unpacking...
        14 May 2011, 09:16 Saturday
      • brac
        Help with settings, oppo/infocus
        by brac
        Hey here is my issue, the OppO dvd player has a bunch of settings for wide not so wide and whatever else... my SP5000 also has similar settings 16:9 4:3 letterbox.... I mostly watch widescreen dvds, any thoughts on what the settings should be?
        Brac
        29 March 2006, 17:20 Wednesday
