System integration question...
  • Martyn
    • 380
    This seems to me to be a system integration question so I hope this is the right forum...
    I have a simple but pleasing two-channel audio system comprising a Denon DVD player, a Linn integrated amplifier, and a recently-completed pair of Eton 3-way speakers. I'm preparing to add a Panasonic plasma TV with satellite feed to replace my rarely-watched 21" CRT and antenna-on-the-roof. The TV I'm considering is the TH-**PHD8UK, either a 42" or 50".
    This represents a significant increase in technical complexity for a simple chap like me, and I'm getting a little confused over how all this stuff will be connected, especially since the TV will not have a tuner or speakers of its own and has limited inputs.
    The TV has the following inputs: composite video (1), S-video (1), component video (1 set of 3), VGA (1), stereo audio (1 pair), PC audio (1), plus an RS232C. It has a single composite video output. A variety of expansion cards are available, but I'm getting lost trying to figure out what I need.
    First question: for satellite TV, the receiver (yet to be acquired) appears to have component video and audio, S-video, DVI-D, and optical digital audio outputs. Am I right in assuming that the appropriate connections would be to connect the component video to the TV and the component audio to my amplifier, and leave it at that?
    Second question: for DVDs and CDs, would the same component connections apply? (video to TV, audio to amp, in which case the TV will be one set short).
    I guess the real question is simply: "what is the optimum way to connect these things for good video and uncompromised stereo audio, and what expansion cards would I need, if any?" Various expansion cards are available to add component video, HMDI video, etc., but they're not cheap.
    In the fullness of time, I will probably change both the amp and DVD player to add 5.1 sound, as long as it doesn't compromise the two-channel audio quality. Would this have any implications for the TV/expansion card question?
    Sorry to bore you with such elementary questions - hope you can help out. Thanks,
    Martyn
  • Booster
    • 14
    The way I did my system was to connect sat box via component video to the screen, optical audio to processor/amp. The DVD player connected via HDMI with the optional card from Panasonic for video and coax for audio. Video switching is by the plasma. Works great.
    The Booster
      Twin Moderator Emeritus
      • 16706
      I also currently run alll my video through the TV. My HD-cable box is connected via component video and analog L/R to the TV (in the event we want to watch TV without the HT system running). Then I connected the digital audio output to my pre/pro for discrete (and matrixed) surround.
      DVD player is connected via component to the TV and digital to the pre/pro.
      • Azeke
        • Mar 2003
        • 2123
        Martyn,
        I run all my components through my Pre-Pro ( Rotel RSP-1098 ) via component wiring for convenience. Some say you should connect directly to the TV to get the best picture, bypassing your receiver, others like myself, enjoy the option of being able to switch everything via my pre-pro.
        However, I am experimenting with HDMI and since my pre-pro doesn't currently support this technology I will have to connect directly to my projector to see if there is any video improvements in the picture.
        Test things for yourself and determine what you like best, afterall experimentation is the fun part of this hobby . Just my $0.02.
        Peace and blessings,
        Azeke
        • Martyn
          • 380
          Thanks, fellas. Sound like this shouldn't be too difficult. I appreciate your comments.
          Martyn
          • skipm
            1098 Analog Audio Weirdness
            by skipm
            Hey Guys-
            I have a JVC HM-DH30000H D-VHS VCR on Video 4 connected via component video 4, optical audio 2, and the analog audio/video 4 inputs. Everything works as expected when playing D-Theater HDTV video tapes (except for no video on the 1098 screen). The JVC will not pass an analog...
            16 August 2003, 14:23 Saturday
          • mattstacey
            Rotel 1066 component video setup problem
            by mattstacey
            Hi guys,
            I just replaced my Denon 3802 with a Rotel 1066 yesterday, hooked up to a Rotel 1075 amp. I haven't had much of a chance to listen to it yet but so far it sounds awesome.
            I have a problem with my video connections though. I had no problems with the Denon 3802 so...
            18 October 2003, 23:39 Saturday
          • saurabh
            What is CVBS-How would this be connected to the TV
            by saurabh
            Upon looking at a philips HTS, I found this specification for connectivity to the TV:
            Connections
            • Audio input:
            - analog : AUX
            - digital : 1 x cinch
            • Audio output:
            - analog : Line out (cinch)
            - digital : 1 x cinch...
            21 February 2005, 06:23 Monday
          • hired goon
            RSP-1068 component video problems
            by hired goon
            G'day,
            I'm having problems with the component input/output of my RSP-1068.
            I finally bought a TV that has component input. I connected my set-top box to the TV via component, and got a great image without any problems after one hour of use. Next I connected the DVD player...
            29 May 2005, 04:59 Sunday
          • WhiteChocolate
            Just Got A New Rotel RSX-1056 Need Audio Output question answered.
            by WhiteChocolate
            I just got a Rotel RSX-1056 and I really like the unit because of the fact that you may send different audio outputs from different audio inputs.
            I have a 400 cd-dvd Changer with S-video and Optical Audio
            Also a Direct TV DVR with S-video and Optical Audio
            The DVR...
            28 March 2007, 12:03 Wednesday
