Component and composite cable Q's. Please lend me a hand.
  • andyraines
    • 3
    I am very new to HT systems, so you'll have to forgive me.
    I recently purchased a new TV and HT system. I was looking for a DVD player when I ran into this problem:
    The TV has component inputs, but my HT receiver has no component outs. Do I have to use the receiver's video monitor (RCA video cable from the DVD player, to the receiver, back out to the TV), or can I go straight from the DVD player to the TV with component wires? I would still obviously hook up the audio through the receiver. If this is possible, could someone recommend a good DVD player also?
  • dyazdani
    • 7032
    I would run component video directly from your DVD player to your TV.
    What price range of DVD player are you looking into?
    Danish
    • andyraines
      • 3
      Ok, so I don't need to run video through the receiver at all?
      I'd like to keep the DVD player around $100. I have coax, optical, and 5.1 multichannel to connect to. What is the best audio option?
        • 27460
        Andy, you may need to hook a composite video cable from receiver to TV just for using the on screen adjustments for your receiver. IF it is designed that way, or some people use an S-video feed for this from DVD to receiver, then receiver to TV, but also hook component vid up direct from DVD to TV, or from satellite receiver to TV for example. So, if your adjusting, then you use the less quality feed, if you are watching a DVD, you flip to component.
        A 100.00 DVD player range looks like a Best Buy or Circuit City special, just pick what seems best looking to you, maybe what's on sale to get more features for the money, or less overall price. But your not going to be able to select like some high end special player for 100 bucks of course.
        That doesn't mean it can't deliver a good image, it can.
        I always prefer digital coax for audio myself.
        Owner
        HTG, CATCables.com
        • Azeke
          • Mar 2003
          • 2123
          No, you don't have to run video through the receiver, it is primarily for convenience, allowing you to control your components through one device.
          Coaxial cable is a good choice, less expensive and more durable.
          As far a keeping your DVD cost at $100.00, that's tough, as previously suggested, try Best Buy, Circuit City (maybe an open box), or perhaps even Ebay or Audiogon.com. If you have the extra money try to move your budget to $200.00, it will provide a better quality player.
          Peace and Blessings,
          Azeke
          • andyraines
            • 3
            Thanks for all the tips guys. As for the player, it probably will be a low budget affair--as I don't have a whole lot of money invested in this setup.
            • chinets
              ROTEL RDV-1092 vs Marantz DV-9600 DVD-Audio/Video SACD Player???
              by chinets
              What is better???????????????
              08 May 2006, 09:59 Monday
            • mattstacey
              Rotel 1066 component video setup problem
              by mattstacey
              Hi guys,
              I just replaced my Denon 3802 with a Rotel 1066 yesterday, hooked up to a Rotel 1075 amp. I haven't had much of a chance to listen to it yet but so far it sounds awesome.
              I have a problem with my video connections though. I had no problems with the Denon 3802 so...
              18 October 2003, 23:39 Saturday
            • Kees
              1098 conversion composite to component
              by Kees
              I'm getting my 1098 tomorrow, but downloaded the manual from Rotel's website. I have a question on the conversion from composite or SVideo to Component. I hope one of you can help me!
              My ideal setup is:
              VIDEO 1: S-VHS player (with S-video cable)
              VIDEO 2: Hi-8 player (with...
              08 September 2003, 14:16 Monday
            • Trevor_J
              Component video switching on RSP1066
              by Trevor_J
              Hi all. It's been a while but I'm back with a problem that I need help with. This weekend I made the jump to HDTV which meant that I would finally use the component switching capabilities of my 1066. I have an updated unit that supports HDTV bandwidth on the component inputs.
              Here's...
              17 January 2005, 01:02 Monday
            • MountainMan33
              Help with component video connections
              by MountainMan33
              My setup is as follows.
              rotel rsx 1055 reciever
              rotel rdv 1080 dvd player
              sony 46 inch lcd moniter.
              My problem is simple, im a a/v newbe and have searched the forum for the answer, i havent found what im looking for. So here it goes
              I have component...
              25 June 2006, 20:16 Sunday
