Samsung HT-P38: getting sound from cable box?
  • mjames
    • 3
    I just got this 5.1 Samsung HT-P38 package and have a Scientific Atlanta 8300HD cable box and a Samsung LTP227W 22" LCD HDTV. My problem is I can't get sound from the cable box to go through my 5.1 speakers when watching TV. How would I do this?
    My TV has component 1 and 2 and L/R audio ports next to those component ones. My cable box is connected via component 2 to my TV, and I ran the L/R audio from the cable box to my Samsung HT-P38 receiver instead of the TV. No sound. I think it has to do with the mode I'm using on my TV. I need to be on component 2 to watch TV, whereas the Samsung HT-P38 is hooked into component 1. (And yes, the speakers are setup properly as I do get sound when using the test feature on the Samsung HT-P38 menu.)
    Thanks!
  • mjames
    • 3
    My setup:
    TV to cable box: component (video and L/R audio)
    Cable box to HT receiver: digital optical
    TV to HT receiver: component
    I get sound when I'm on Component 1 and watching DVDs, but nothing on Component 2 for TV. Is there a way to change the INPUT on the HT receiver so it knows digital optical? I'm totally confused!
    • mjames
      • 3
      Fixed! I changed the input on the receiver to DIGITAL IN using the function button on the front of the receiver. Couldn't find out how on the remote, but whew.
      • CPALIU
        RSX 1057 & Charter HD Cable Box 3500HD problem
        by CPALIU
        I'm running into a problem with my Rotel RSX 1057 & Charter HD cable box (3500HD). I have the cable boxed hooked up to the RSX-1057 using component cables to Component in 2. When I select video 2, I get the cable signal just fine from the cable box. Howeve,r when I push the menu option on the...
        18 August 2006, 11:31 Friday
      • Kush
        Difficulty with HDMI input from Cable box to TV via receiver
        by Kush
        My set up
        TV-Sharp Aquos 46" 1080p
        Receiver - Pioneer Elite VSX84 TSXI
        Cable Box - Shaw Digital box (Canada)
        I tried to hook up the cable box to the receiver to take advantage of the HDMI connections. However the picture does not go through to the TV...
        04 December 2006, 17:45 Monday
      • vasia
        Need help hooking digital cable box to the receiver
        by vasia
        I am trying to hook up Motorola digital cable box DCT2500 to my Marantz SR8300 receiver. I connected digital out of the DCT2500 (did not have optical out) to the digital in of the Marantz and it plays fine. THe only problem is that even when the program is listed on the TV as Dolby Digital, the receiver...
        24 June 2004, 08:51 Thursday
      • june
        Comcast's new HDTV cable box!!!
        by june
        Hello All,
        Comcast has a new HDTV cable box verson 3 with a HDMI output. My sony HDTV only has a DVI input. The cable installer brought this new box with a HDMI to DVI cable. This didn't work properly. No picture after a hour or so of viewing. We had to switch back to component output...
        27 March 2006, 11:36 Monday
      • canaanskier
        Rotel 1050 Simultaneously Power on TV and Cable Box
        by canaanskier
        I have a Comcast Motorola 6412 DVR and Sharp 37" LCD and the Rotel 1056 receiver. I would like to be able to turn on the cable box and tv simultaneously using the Rotel remote 1050. Do any of you know how this is done, ie. program the remote to turn on these two devices at the same time? Thanks...
        04 November 2005, 14:55 Friday
