Problems with the LG DV7832NXC through component
  • froggi3
    Just purchased the LG DV7832NXC and cannot get it to work through component output! The screen is black and white, out of focus, and seems to be broken up into 4 sections(a faint cross is though the middle of the screen). I've tried the firware update but get the same problem.
    No problems through s-video, but I purchased it for component upconverting, am I doing something wrong, or is the player screwed? I have tried 2 other older dvd players through component just to be sure and they work fine. I purchased it at Best Buy and they had 1 left, $50.00 bucks says that when I return for exchange tomorrow, it'll be gone.
    Any fixes, hints, help??
    Thanks.
  • m_bathke
    • 48
    BestBuy services what it sells, so if the unit is still under manufactuer warrenty, take it back and they will get it fixed or exchange it for a new one.
    • mvoorberg
      • 14
      froggi3, please keep us posted. I was just about to buy one of these for the upconversion over component and am having some serious doubts about it. I am a bit of a tweaker, but love the fact that my current DVD non-progressive player just plain works. I've never had problems with it and it plays everything I've ever put in it.
      I would be feeding it into a PB6210 FP and have no idea what to expect with respect to PQ improvements over my current player. Would I see a difference in smoothness or does the projector already do progressive scanning when it paints the picture?
        • 16061
        Well, I have one of the Zenith versions, the DVB318, and it's always worked fine. Double check your cable connections for the luminance and color difference signals.
        What display are you trying to use?
        I used mine with an NEC CRT projector, which means I had to use a component to RGBHV transcoder; but I've also tested it into a Sony VPL-W10HT without any problems, as well as an NEC XM29+ presentation monitor.
        ~Jon
        • DeanP
          • 175
          froggi3:
          Unless you have a progressive scan tv, component will not work, only thru s-video only.
          I myself have one of these LGs but I can't use component until I purchase the progressive tv... :cry:
          • hidefdvd
            • 60
            WHat TV do you use in your setup? As DeanP said unless its a progressive set it won't work. Also is it a HD setup, able to take a 760p or 1080i signal?Another thing to look at is the resolution setting on the DVD player itself. Maybe you have it set too 760p when it should be 1080i or the other way around.
            • Uncle Clive
              Former Moderator
              • Jan 2002
              • 919
              There are TVs with component video input that cannot accept progressive scanning. However, the DVD player can output signals through Component video without turning on the progressive scan feature. Therefore, froggi3 your DVD player may have (1) A switch at the back of the unit that needs to be toddled between S-vdeo (same for composite yellow video) OR Component video y Pb Pr and (2) as mentioned above that you may need to access the menu and choose the right signal output. Make sure the component cable colours are matched properly. Start by turning the Proggresive scan OFF first. BTW. Progressive scan switching may also be a button on the remote marked I/p :idea: (for interlace or progressive).
              CLIVE
              • dmcgowan
                HELP - RDV-995 / RSX-1055 Component Video
                by dmcgowan
                I lashed out today and brought home a 42" Plasma
                Rearrange the room, new cables connected, etc etc and everything works fine except for using the RSX-1055 to switch component video from the RDV-995.
                I can direct connect the RDV-995 to the Plasma and get...
                25 October 2005, 08:43 Tuesday
              • Ezgoin
                Anyone else have this component video switching problem?
                by Ezgoin
                Hi all,
                I'm a proud new owner of the RSP-1068/RMB1075 combo and while I'm still getting used to the controls, I'm experiencing a system power-up problem that I'm wondering if anyone else has had. I'm switching my HD cable box and DVD player component outputs through the 1068 and into the DTV...
                11 August 2004, 09:03 Wednesday
              • Mark_E
                Lg Dv7832nxc
                by Mark_E
                After extensive research into new DVD players, I decided to try out the LG 7832 with Nov of '03 build. I am running a Toshiba 51HX83 RP. One thing I have noticed with other DVD players, for whatever reason, is that the picture quality using component always seemed to be inferior to the s-video, regardless...
                01 January 2005, 10:41 Saturday
              • bleeding ears
                2nd RSP 1068 Dead, Any alternatives?
                by bleeding ears
                Hopefully someone at Rotel in Australia may read this.
                After waiting 3 weeks for it, and then having to send back my first 1068 processor (at my expense) because it had no output signal for the subwoofer or centre speaker, I thought surely they will ensure the replacement unit is working...
                14 November 2005, 10:25 Monday
              • hired goon
                RSP-1068 component video problems
                by hired goon
                G'day,
                I'm having problems with the component input/output of my RSP-1068.
                I finally bought a TV that has component input. I connected my set-top box to the TV via component, and got a great image without any problems after one hour of use. Next I connected the DVD player...
                29 May 2005, 04:59 Sunday
