James Audio Vs Svs Pb12 Ultra
  • MICHAEL STRO
    • Oct 2003
    • 100
    doe's anyone have a james audio sub,and do you like it. a friend of mine was thinking of buying a james emb-1200. I have a svs pb12 ultra and I always rave about the sound. the salesman at the audio store said the james sub is the best for the money in it's class and he would put it up against any other sub in the same price range. well since both subs are around $2000,00 dollars U.S. we did a test in my house with both subs. the svs blew the james away in our opinion.there was no comparison.the salesman could not believe this.has anyone tested the james subs, your thoughts would be greatly appreciated.
  • Kyle
    • 233
    Well, I haven't heard a james sub, but I'm considering purchasing a SVS sub to accompany my 600 series b&ws.
    Prior to purchasing rotel gear, I was using the crappy bass-boost functionality of my receiver, and now I miss the boom that my 603s put out prior to getting my rotel gear. Even with sub set to no and a low crossover on the fronts, I haven't been too thrilled with not having a subwoofer.
    I'm probably going to go cheap on the sub and get whatever the entry level 10" model of the SVS box subs is, as I'm in a "small" nyc apartment, but I've heard good things about SVS all over the place. Glad to see that a fellow htguider is happy with their SVS.
    My gear
    • Peter Marcks
      • 7
      Dear Michael,
      You should feel good about your system. Do not let a third party salesman convince you otherwise.
      That said, it is not entirely equitable to compare a retail channel product to a factory direct product of similar price. The products in retail as a general rule must be priced higher, as they must account for dealer markup and costs of running a dealership. Primarily for this reason, many factory direct products are considered to be of higher value. Also, products in retail often have street prices or negotiated prices that differ significantly from manufacturer suggested retail prices, so this makes price point comparison especially difficult with factory direct models.
      Another thing to look at is size. The James EMB-1200 is much smaller, with a hxwxd (in inches) of 15x15x18. Per given enclosure size, the James probably does fine.
      Perhaps the most fundamental idea in subwoofer design is the idea of tradeoff. Ultimately, each consumer should choose the product that they feel compromises in the least number of areas that they consider to be important to them.
      Cheers
      Peter Marcks
      Hsu Research
      • Sonic-x
        SVS PB12-Plus/2 compared to B&W ASW850 subwoofer
        by Sonic-x
        I have a ASW850 subwoofer in my setup right now. This is a demo used item which I can get for a reasonable price, about $2600, retail price in Norway is about $3900
        But then there is the SVS PB12-Plus/2 which I can get brand new for about $1950 retail price. This subwoofer is said to...
        28 November 2005, 18:15 Monday
      • Prozakk
        SVS induced picture distortion...
        by Prozakk
        I have a Samsung 47" tabletop HD RPTV. The other day I was testing out my new SVS PB12-Ultra/2 w/some music, while watching tv & the whole left side of the picture distorted to the beat. :evil: 8O I did have the music up loud. :E :T
        What should I do? Warranty repair? Put...
        27 October 2004, 18:39 Wednesday
      • dave shepard
        803's are haunting me
        by dave shepard
        Little over a year ago I heard the 803's for the first time and ever since I can't seem to get their sound out of my head. I keep compairing them to my current Polks I use for HT. There were only 2 running for a demo for another customer and above all the other speakers playing they stood out as though...
        13 September 2005, 23:02 Tuesday
      • Markmm
        Q? about SVS Subs
        by Markmm
        Trying to decided between the PB12 Plus /2 and the PB12 Ultra. The Plus / 2 has 2 12", while the Ultra has 1 but of better quality. I sent SVS and e-mail and they said it was a matter of taste, but the personally he liked the added feel of the 2 subs over the higher quality 1 sub. They're both...
        15 November 2005, 13:48 Tuesday
      • Vinny
        Cutting down my system
        by Vinny
        Hi guys.... I am a total stranger here again for moving here and there for the past year
        Anyway I finally moved to NYC and settling down here, good news is it's NYC here! Bad news is I have to cut down my system from moving suburb to the city
        My current setup...
        19 November 2008, 09:30 Wednesday
