My turntable is a dust magnet!
  • Kevin P
    • 10812
    While spinning some vinyl, I became painfully aware of how much dust had collected on my Denon DP-300F turntable... not just on the dust cover either... the plinth was coated in dust as well, even though it spends nearly all its time with the cover closed. I've kept the platter and the cork mat clean, and my records of course, but after I wiped down the dust cover and plinth, I realized that the dust cover is pretty much made of static electricity... literally... the hairs on my arm stand up if I bring them near the dust cover.
    I removed the cover and wiped it down with a damp cloth and put it back on, and there's less static now, but why would they make a turntable out of a plastic that attracts dust like that? I know... because it's cheap...
    Anyway, any recommendations for some sort of anti-static wipes or something I can use to keep my TT clean?
    not much you can do other than regular cleaning....
    i recommend using high-quality micro-fiber towels, that kind the car guys use on those super cars....
    i actually use this stuff, too....
    link to towels
      • 4158
      And they seem to make them with the softest plastic possible, making them easily scratched by careless dry wiping.
        • 27460
        I try and cover my odd table, which really isn't a table at all, but two round cylinders with a giant rubber band, ha. But I haven't used it as much as I had intended... Time is big factor, and my wanting to play a bit of guitar when I have time, etc...
        • Kevin P
          • 10812
          No anti-static cleaner recommendations?
          I don't use mine that much either, so it sits collecting dust, even with the dust cover on. Turns out there's rubber bumpers on the dust cover that leave a tiny gap that lets air (and dust) in. And since the dust cover and plinth are basically made out of static electricity that's been condensed into a plastic-like material, it attracts dust like a magnet.
            sometimes you just cant overcome mother nature......:huh:
            • Kevin P
              • 10812
              It's funny how I can revisit a thread months later and catch something I missed before...
              I got a good chuckle out of the thought of detailing a turntable. :lol:
              My turntable has sat unused for a few months as well...just checked it, and the dust cover is dusty but the plinth isn't as bad... maybe my last cleaning reduced the static somewhat... but then we've had nothing but rain for the past 3 months, maybe that's keeping the static down as well.
              • palmetto
                turntable stabilty - swivel shelf? speaker vibrations?
                by palmetto
                i have a technics SL-1300 (1976 vintage) and will resurrect it for my new ht system. it weighs, maybe, 25 lbs. (?).
                i am building a very solid wooden wall unit, floor to ceiling, with 20" deep shelves. but many of the shelves are not high enough to handle the 6"-15" opening...
                12 April 2004, 20:33 Monday
              • rick c
                Dust covers on 603s3's - Worth removing?
                by rick c
                I was reading some reviews on the 603s3 and they mentioned removing the black dust cover making them sound better.Does anyone know what they are actually talking about?or has anyone heard of this?what is the dust cover?
                24 December 2004, 05:47 Friday
              • rdram
                Best $79 Tweek
                by rdram
                For all you analog lovers our there, this is one great product. To digress, I got back into vinyl last year...purchased an entry level Project turntable to get back to all those vinyl disc's I've had in storage for years. It's been a blast spinning vinyl again, but to be honest, doing so brought back...
                27 March 2015, 20:09 Friday
              • Kevin P
                We need more vinyl/turntable discussion
                by Kevin P
                My hobbies and interests wax and wane, as I burn out on one and take up another... and recently I've started spinning those 12" vinyl discs again while I work.
                Love the experience and the sound, and knowing that with some tweaking I can make it even better.
                Learning...
                06 March 2019, 13:48 Wednesday
              • jjahshik32
                Anyone here know if its a good idea to leave the cover on or off on b & w speakers?
                by jjahshik32
                does it collect more dust if you leave the cover off, or is it about the same? The reason i'm asking is because I want to leave the cover off of my 805s because it looks so nice but then I dont want it to build up with alot of dust in there.. also does the speaker produce better sound with the cover...
                18 September 2007, 18:20 Tuesday
