Amp recommendation for Sadhara
  • eddiem67
    • 139
    Ok I have this sweeet a$$$$$$ sub, I want to put about 1000 watts to it. Can anyone recommend me an amp. cheap or expensive, as long it is clean power.
    My Car Audio
    • 16145
    A lot of folks go out and buy a pretty serious subwoofer with great Xmax and the attendent relatively low efficiency, then try to low ball the amplifier, often going with a relatively "lightweight" pro amp that has lots of watts (rated) per the dollar.
    With my experience on amps for full range speakers, my feeling is that a really good solid power supply is quite necessary for tight, deep, NATURAL sounding bass.
    In your shoes, I'd consider shopping Audiogon for a good used amp, such as Bryston, Aragon, etc. Just my 0.02. Not every one is a nut case like me, and likes bridged Aragon 8008BB or Palladium monoblocks as sub amps, but they sure do grab hold of a big sub and don't let go (Stryke HE15, for example).
    Many other good choices out there, though, so don't be afraid to shop around.
    ~Jon
    • jimmyp58
      • 1449
      Simple --- Bryston 7B SST.
      jpiscitello@ameritech.net
        • 16478
        I'm using a Samson S1000 which is one of the sub amps SVS is selling on their site. I got mine used for very cheap and it seems to do a nice job with my IB but as Jon points out its not the be all and end all for power amps...but given a restricted budget if I'm going to spring for a Aragon amp it sure won't be powering my sub :B
        • eddiem67
          • 139
          Thanks guys, anybody else, these amps are nice but pricey, but it is exactly what I am looking for, since my rack is open and I dont want anything with a fan built in (noise). Are there any model that are cheaper out there, I am willing to go down to 600-700 watts.
          My Car Audio
          • aarsoe
            • 795
            My experience is a little different. Sure - you can get very good D class power amps, but a well built amp with lots of current will do the same trick with a lot less wattage.
            So unless you can find a ice power module (and they are not sold seperatly) I would recommend to find two of the old Marantz MA700 power amps (mono) and bridge them.
            They even have the bridging built in so it is very easy to do.
            Should be a cheap and very good sounding solution.
            You should be able to find them on e-bay for a couple of hundreds each..
            • chasw98
              Aragon 4004 Power Amp
              by chasw98
              First post over here. I am usually in the DIY section. I want to buy a used high end amp. I have an Outlaw 950 pre/pro and WWMT DIY speakers. I am currently using a Behringer EP2500 power amp to drive them. I believe an Aragon 4004 or 8008 would serve me better. I'd also consider Bryston if they were...
              28 June 2006, 20:42 Wednesday
              Next B&W Upgrade. Your opinion?
              by Race Car Driver
              Ok, im getting the itch again to upgrade my system.
              Now I have two choices for the next step.
              Upgrade my amp (looking at used rotel 1090s) for the 802s. Currently using an Aragon 4004 200wattx2 amp.
              or
              Upgrade the center to a used HTM 1 (but...
              15 June 2006, 23:38 Thursday
            • Ricky
              Outlaw 950 vs Aragon Stage One (in the house!!)
              by Ricky
              A friend of mine had a few days left before he had to return his 950 back to Outlaw (he bought the AT Clone and uses an Anthem Pre2L for his 2 channel listening). I thought why not? This is a good chance to try the Outlaw in my system for a couple days. I did a few comparisons the past 2 nights and...
              06 April 2003, 01:03 Sunday
            • Jeff Aguilar
              Sent friend to get Rava, he buys Sadhara
              by Jeff Aguilar
              I have been helping a friend put together a new system for his home. They had a very limited budget they wanted to spend. They did not want to spend over $300 for a receiver and not over $300 for a sub to be purchased at a later time.
              I did talk him into going for the Outlaw 1050 at $499. While...
              19 March 2003, 15:34 Wednesday
            • gostan
              Bi-Amp Center Channel?
              by gostan
              I will be re-connecting all of my speakers with new upgraded speaker cable today or tomorrow. Now my system upgrades are almost complete. Except for a desire to change a few interconnects, the main weakness in my system is that I am still using a Rotel 1075 5 channel amp to power my rear 805's, a...
              31 December 2004, 08:59 Friday
