So I listen to a fair amount of AM radio, especially sports talk in my truck. I like to listen now and then at home, especially when my Texas Tech football games are on. The problem I'm having is I cannot for the life of me get a decent AM signal out of my AVR (Denon 2307CI). I manage to get pretty great FM reception with the included coax wire style antenna, but plugging in the included AM loop antenna, I can barely get anything and even if I do it's not listenable. I have a small Tivoli radio and with its loop antenna in the same room it sounds much much better. Is this just a function of Denon not putting much thought into the AM hardware? Does anyone think a better/amplified antenna would make a difference?
AM radio help
No real experience with your issue, but I do have an idea.
Check out CraigsList for some vintage receivers. The old ones like Kenwood, Marantz, Sansui, Yamaha & Carver, for example, had V good AM receivers. You might find a decent unit for cheap.
You could call Vintage HiFi of Pgh for some advice on what to look for. Keep in mind the shop usually does not open till 4:00 PM.- Bottom
That does sound like a good idea, but would probably be a last ditch effort. I'm trying to go with as few components as possible. If I really just wanted what I have to work I could just plug the Tivoli in but I'd like to just use my existing receiver. I'm hoping just a nicer antenna would help and mainly looking for recommendations on one.-Chuck- Bottom
You could always get a piece of wire (speaker) and connect it up to the AM terminals and see what you get with a better wire and just loop it and see... That might be all you need to get a better signal...maybe not...but an option.
My Rotel Radio is awesome, best sound I've heard from radio and it picks up just about everything in range (and it's in the basement next to 2 walls with earth behind them).Digital Audio makes me Happy.
-Dan- Bottom
by praneethHi All,
I have seen ur valuable comments and expert opinions reg. HTS.
I am planning to go for HTS i have LX3600D in mind. Its a build in DVD player.
with following spec:
Philips Home Theatre - 9000 W
The full cinematic sound experience can be yours....-
by H.T.CThere is a new radio thats to come out called the {it was to be called the grundig satellite 900} eton e1 xm that contains : 1) xm satellite radio and digital audio band which is the new broadcasting standerd that i think upgrades shortwave and am radio to almost fm sound quality in stereo and fm to...30 March 2004, 12:57 Tuesday -
by BlindamoodOkay, time for a new thread...I've been listening to a lot of Internet radio lately (via my Logitech Transporter and Duet), and wanted to share one of my favorites.
When I was in college at Miami University in Oxford, Ohio, there was a cutting-edge alternative rock station (97X) that...-
Channel: Audio Hideout
by HuskerduckI really got tired of 5 remotes laying about and have always forgot to pick up a Cinema 7, Pronto or whatever and was with the wife Christmas shopping and stumbled into Radio Shack because I remember hearing they had a good "all in 1" remote.
This remote isnt much bigger then a RCA...17 December 2000, 13:21 Sunday -
by J.H.I know off topic for this forum but I am my wits end. I have had Sirius radio in my truck for a few weeks now. I have the sportster sirius radio in my truck and have no problem with reception. I just bought the Sirius sportster SP-B1 boombox and connot get reception at all really. I moved the satellite...-
- Loading...
- No more items.
