Home Theatre System
  • praneeth
    Home Theatre System
    Hi All,
    I have seen ur valuable comments and expert opinions reg. HTS.
    I am planning to go for HTS i have LX3600D in mind. Its a build in DVD player.
    with following spec:
    Philips Home Theatre - 9000 W
    The full cinematic sound experience can be yours. With a 6 channel full digital Class D Amplifier, DTS, Dolby Digital 5.1 and Dolby Pro Logic II the LX3600D is fully loaded.
    The integrated DVD player wit+O9h progressive scan is not only fully compatible with DVD, DVD+R, DVD+RW, CD, CDR and CD+RW, VCD and SVCD, but can playback MP3 and picture CD's.
    This powerful Home Entertainment System is extremely easy to set up, thanks to its color-coded connections.
    Superb audio and video performance
    6 channel full digital Class DTM Amplifier
    Wide Spectrum Speaker System
    Progressive Scan for razor-sharp and flicker-free images
    Plays practically any disc format
    Movies: DVD, DVD+R, DVD+RW, VCD, SVCD
    Music: CD, MP3-CD, CD-R, CD-RW
    Pictures: Picture CD (JPEG) with music (MP3)
    Quick, clean and easy set-up
    3-step easy set-up
    Color-coded Easy-FitTM connectors
    Dual orientation subwoofer
    Standard Product Information
    Playback formats
    Video: DVD, DVD+R/RW, VCD, SVCD
    Audio: CD, CD-R/RW, MP3-CD*
    Pictures: Picture-CD (JPEG) with music (MP3*)
    * Plays MP3-CD (supports 32, 56, 64, 96, 128, 256 kbps and variable bitrate)
    DVD functionality
    Multi-angle functionality
    Audio selection
    Parental control
    Repeat track/disc/A-B
    Program, Resume, Zoom, Slow
    Receiver functionality
    Rock, Digital, Jazz, Classic, Drama, Action, Sci-Fi, Concert
    Dolby Digital, DTS and Dolby Pro Logic II
    Class DTM Amplifier for high quality audio performance
    Tuner (Radio)
    FM/MW Digital tuning with 20 presets and automatic installation
    Amplifier
    6 x 50 watts RMS
    6 x 600 watts PMPO
    3600 watts PMPO
    Loudspeaker boxes
    Magnetically shielded front and center
    4 Two-way satellite speakers (L, R, SL, SR)
    - Frequency Range: 120Hz~20kHz
    - Impedance: 4 ?
    - Drivers: 3'' full-range woofer
    - 1'' piezo
    Two-way Center speaker
    - Impedance: 4 ?
    - Drivers: 2 x 3'' full-range woofer
    - 1'' piezo
    Subwoofer with horizontal/vertical option for flexible installation
    - Frequency Range: 30Hz~120Hz
    - Impedance: 4 ?
    - Drivers: 6.5'' high efficiency woofer
    Connections
    Audio input:
    - analog : AUX
    - digital : 1 x cinch
    Audio output:
    - analog : Line out (cinch)
    Video output:
    - CVBS (Yellow cinch)
    - S-Video (Hosiden)
    - Component Video (Y, Pb, Pr)
    Antenna : FM coax, MW loop
    Speakers : socket connectors
    Video performance
    Progressive Scan : NTSC
    Video decoding : MPEG-2/MPEG-1
    Video format : 4:3 / 16:9
    Video System : PAL/NTSC
    Video DAC : 12 bit
    Audio performance
    Audio DAC : 24 bit, 192 kHz
    Signal to Noise ratio (1kHz) : >95 dB
    Frequency response : 30 Hz - 20 kHz
    Power supply
    Power requirement: 220-230V, 50Hz (/75, /93) 110-240V, 50-60Hz (/69, /78)
    Power consumption: 80 watts
    Eco power standby: <2 watts
    General
    45 keys Remote Control
    Local and On Screen Display
    Class DTM Amplifier
    With up to 95% efficiency, Class D Digital Amplifiers mark a huge advance over traditional AB type amplifiers, resulting in high-powered pure and digital sound quality.
    Dolby Pro Logic II
    Dolby Pro Logic II brings out the hidden spatial cues in all existing music recordings in a natural, convincing way. Dolby Pro Logic II decoding lets you transform Dolby Surround and stereo courses - including music - into convincing 5.1 sound for powerful and realistic music and home theater sound.
    Progressive Scan
    Progressive Scan doubles the vertical resolution of the image resulting in a noticeably sharper picture. Instead of sending field with the odd lines to the screen first, followed by the field with the even lines, both fields are written at one time. A flicker-free high resolution image is created giving you the best viewing.
    Dimensions (Product)
    - DVD System: 360mm W x 54mm H x 316mm D
    - Surround speaker: 89mm W x 162mm H x 70mm D
    - Center speaker: 234mm W x 96mm H x 70mm D
    - Subwoofer: 220mm W x 230mm H x 360 mm D
    Warranty : 12 Months
    MRP: INR: 16990.00 USD: 386.10
    Is it advisible to go with or any suggestions for option HTS with DVD player
  • Uncle Clive
    Former Moderator
    • Jan 2002
    • 919
    Praneeth we are extremely happy to have you here. Welcome :T
    As with most THIBs they do have there pluses for ease of use and today they do quite well processing/decoding material at acceptable levels. If this is what you're budget allows by all means go ahead. Just remember that THIBs are often not upgradable.
    But I would also advice you if possible to audition a fully equiped home theater at your local dealer to have an idea of what the ultimate system will sound and feel like. Then if possible audition the system/s you're are interested in to come as close as possible.
    The Phillips will make a tremendous improvement in the way you'll enjoy your movies and TV programs.
    Go ahead take the plunge!!
    CLIVE
    • Uncle Clive
      Former Moderator
      • Jan 2002
      • 919
      Praneeth as a side note you may want to follow the comments posted in this thread http://htguide.com/forum/showthread.php4?t=14525
      Hope this helps :T
      CLIVE
      • Buzz Goddard
        Pro Logic II
        by Buzz Goddard
        Just after TAG McLaren finished the 7 channel THX Surround EX Upgrade, adding Dolby EX, DTS-ES 6.1 Matrix and TAG McLaren Surround 7 to existing AV32R 5.1 processors, Dolby Laboratories announced the introduction of Pro Logic II, the next generation of Dolby Surround Pro Logic decoding technology. Pro...
        17 December 2000, 10:10 Sunday
      • Razvan
        Dolby Pro Logic IIx upgrade?
        by Razvan
        "Dolby Laboratories Unveils Dolby Pro Logic IIx
        posted by Chairman Steve - 2003-09-02
        Technology provides up to 7.1 channels for stereo and 5.1-channel content
        Indianapolis, September 2, 2003—Expanding upon its tradition of leadership in providing enhanced...
        05 September 2003, 19:40 Friday
        Dolby Digital Plus
        by Andrew Pratt
        Dolby demos Dolby Digital Plus
        Are you ready for 13.1 sound? Dolby Digital Plus features more than 10 times the bandwidth of Dolby Digital.
        LAS VEGAS--Dolby Digital has seen some enhancements over the years as it's become the most common multichannel standard. But in the not-so-distant...
        07 January 2005, 14:52 Friday
        New 9.1 channel Dolby Pro Logic IIz
        From a news release I just saw of the first receiver, (Onkyo) with the new Dolby Pro Logic IIz technology that extracts to 9.1 channels. I chased down this technology report on the Dolby website. Very interesting.
        I'm surprised that I hadn't heard of this before! My thoughts in another post...
        12 March 2009, 07:06 Thursday
      • Scherr
        Dolby pro logic IIx question
        by Scherr
        Picked up me new Rotel 1056. Huge improvement over my old Denon 2800 although the Denon powers the back center surrounds and the second zone.
        My question is this. I want to use dolby pro logic IIx as a default for everything. I set it that way in the menu. On dolby digital, I got...
        16 May 2004, 15:58 Sunday
