Dedicated power amp or reciever
  • CRIMSON PEARL
    • Mar 2008
    • 16
    Hello I'm primarily an audiophile (2 channel stereo music)
    My question is-
    I have a older yamaha MX 2 power amp that I am considering using for the front speakers with the pre amp out from a newly purchased Yamaha RX-V2700. Does anyone know which would give me better 2 chanal stereo for music. Or what the down side would be if any, for suround mode.
    Thanks :B
  • GregLett
    • 755
    If you are a two channel guy, and you want great sound you need to go with separates amp/pre/cd player. This way you can have options, with a receiver you do not have an option with your amp preamp choices.
    It all depends on what you are after. If you are not going to be nuts about it then a receiver will do just fine. If you want to have fun tweaking then get separates.
    Greg
    • littlesaint
      • 824
      That's sort of what the OP described. The power amp will be used for the front channels utilizing the AVRs pre-outs, and the rest of the HT channels will be served by the AVR. Should be a good setup, provided its a good power amp. The v2700 is no slouch.
      Santino
      • Allegiance
        Rotel Pre&Power for Bedroom
        by Allegiance
        I am looking for a system for my Main Bedroom as this is where I spend 90% of my time (when I'm not at work that is!).
        I currently have a Denon AVR-2803, Pair of Def Tech Studio Monitor 450's, 12inch Energy Sub, Samsung 32inch LCD, Denon DCM-280 CD Player and a shitty...
        20 September 2006, 18:36 Wednesday
      • PMazz
        Troubleshooting speaker/amp
        by PMazz
        I've got a wierd one.....
        Background and equipment:
        B&K AVR307 reciever 7 channel.
        B&K 7250 5 ch amp.
        Center channel speaker - DIY Eros MTM using series xover designed by Wayne J. at speakerbuilder.net.
        I had built the Eros in a sealed enclosure...
        06 January 2004, 19:24 Tuesday
      • thyname
        RB-1080 or RB-1070 power amp to purchase?
        by thyname
        Hi guys: As I am thinking more and more to upgrading to separates, I came to a question of whether should I consider a 2 Ch RB 1080 or RB-1070. I initially thought of just purchasing 1070 as it is USD 300 cheaper and I think 130 W per channel is more than enough. However, I know that 200 per channel...
        28 April 2005, 10:31 Thursday
      • Maddog69
        Amp to reciever
        by Maddog69
        hey guys i have a kenwood VR-705 with a $4000 pair of floor speakers and i want to get an amp for the reciever but before i buy the amp i want to know how do i hook the amp to it i was gonna buy a mackie 1400 watt amp each of my floor speakers hold up to 300 watts a piece and before i buy the amp i...
        25 May 2005, 09:14 Wednesday
      • Tibor
        AMP'S
        by Tibor
        Howdy All
        This is a question about amps hooking up an amp to my reciever .
        I have a Onkyo M-501 and a Sony reciever . The amp has 4 speaker inputs , and is 2x150 watts.
        If my reciever puts out 75 watts and my amp puts out a 100 does the speaker get 175 watts or did i mess...
        02 March 2002, 21:59 Saturday
