I've got a wierd one.....
Background and equipment:
B&K AVR307 reciever 7 channel.
B&K 7250 5 ch amp.
Center channel speaker - DIY Eros MTM using series xover designed by Wayne J. at speakerbuilder.net.
I had built the Eros in a sealed enclosure originally using Wayne's parallel xover. I then changed it to his updated serial xover for a listen and it wound up staying that way. It was powered with the B&K receiver. At some point....don't remember when exactly.....the output resistor blew in the reciever. The symptom was a very noticable hum and the woofers were being pushed out only when the receiver was off. When on it worked fine. I did some research and found out it was likely an output resistor on the CC amp of the reciever. Since then I've been using the 5th channel of the amp to power it. I was watching a movie the other nite and noticed considerable distortion out of the CC. It sounds like clipping. I then switched amp channels and it sounds fine. I then switched it back to the reciever and it sounds fine...as long as it's on. I switched the CC with an old JBL I had and it works fine. Thinking it was something blown in the xover, I took it apart and checked the components. Everything checked out.
One of the caps looked a little burnt, but it checked out . My soldering must've been a little sloppy.....
Is there something else besides capacitance to check for a cap?
Any other ideas?
Pete
B&K 7250 5 ch amp.
Any other ideas?
Pete
