Balanced XLR or Unbalanced RCA
  • Stage1
    • 23
    Hi, could anyone explain the diferrence between these two setups and which one is better for overall performance and why? Thanks
  • Kevin D
    • 4601
    Moving since it's a general topic and not Rotel specific.
    Balanced uses three wires to send the signal; Signal+, Signal-, and ground. In an unbalanced cable you have two wires; Signal+ and Signal-/ground.
    Balanced has the potential to give you lower noise & less interference, especially over long cable runs. You typically won't hear a difference unless all pieces in the system are truly balanced and you are using long cables runs.
    Kevin D.
    • MIB
      Subwoofer connection. Balanced/unbalanced.
      by MIB
      Hello.
      I am just about to take delivery of an SVS P2B+ subwoofer.
      Currently I have a Parasound C2 pre-amp processor.
      Connected to it are 7 mackie 624 active speakers.
      These are connected to Balanced outputs XLR to XLR connectors.
      04 May 2004, 09:44 Tuesday
    • Mikez
      Can I use XLR to connect RSP1582 to amp and RCA to connect RSP1582 to sub?
      by Mikez
      I'm hoping someone can help me out. I'm contemplating getting a Rotel RSP 1582 preamp that has XLR outs so that I can connect my preamp to my amp using XLR's (balanced connection). Would it be possible to use RCA (unbalanced) out to connect my sub, a Vandersteen V2W, while at the same time connecting...
      09 March 2020, 18:07 Monday
    • Scarp
      Club Parasound F.A.Q. (Last Updated 21 Jan 2012)
      by Scarp
      (New information will be italicized to be easily identified)
      1. Introduction
      This is our FAQ for Club Parasound. We intend to add more as it becomes available or when we have time to update it.
      Please feel free...
      22 December 2003, 14:51 Monday
    • Blazin
      XLR to TRS stereo
      by Blazin
      Need to output from 1/8" TRS Stereo (Pocket PC) -> Balanced Audio IN XLR..
      Got a 1/8" jack and a XLR-3M jack.. just need to solder the wires together..
      XLR-3M has pin 1GND, 2Hot, 3Cold
      1/8" jack appears to have 4 conductors, L, R, GND, ?Shielding?...
      07 March 2008, 12:55 Friday
    • Fre.Mo
      balanced input for RC1090
      by Fre.Mo
      I am in FRANCE. I bought a RC1090 pre amp and I would used balanced input on XLR connections.
      Please can you tell me if this amp uses :
      - the USA xlr system (1: GND, 2: COLD, 3: HOT)
      - or the European system (1: GND, 2: HOT, 3: COLD).
      My Cd...
      13 July 2005, 08:38 Wednesday
