Active Monitor Suggestions?
  • Russ L
    • 544
    Does anyone have experience with active monitors? What are the best brands? What are the pros and cons of having the amp inside the speaker? I heard that Genelec is excellent. Any other suggestions? Looking in the $2000-$5000 range. Thx, Russ
    Russ
    Twin Moderator Emeritus
    • 16706
    Genelec was going to be my suggestion :T
    • Alloroc
      • 2580
      Dynaudio have some offerings too... Their BM15A is spectacular. My brother uses them in his studio. They cost about €2k each so could be in budget. There are cheaper and more expensive in their lineup so there are options too...
      Vincent.
      • jack667
        • 174
        Domestic or professional environment?
        ATC support both - from all budgets
        Don't think theres much better out there than ATC... or you could look at PMCs active range
        • Russ L
          • 544
          From preliminary investigations looks like you guys have come up with the top 4 companies that provide active monitors for the recording/broadcast biz. Thx for the quality suggestions, thats what I needed. Russ
          Russ
          • cinema bob
            • 154
            Also have a listen to KRK I find that they are the most pleasing to listen to.
            • Burke Strickland
              • Sep 2001
              • 3161
              Also, depending on your definition of "monitor", other high quality choices for active speakers would include Linn and Meridian, although most configurations would be out of your stated price range when new.
              Another possibility would be to mate a mini-monoblock such as the Bryston PowerPac 300 SST (which could be mounted on the back of a speaker or placed very close to it) http://www.bryston.ca/pp300sst_m.html with an excellent passive monitor of your choosing. Of course, that option would require one mini-monoblock per monitor speaker. You would pretty much achieve the objectives of active speakers which retaining the flexibility to upgrade the speakers at some later date without having to give up / replace the superlative electronics.
              Burke
