Soooo..... I know this may ruffle some feathers, especially since this is my first post (hi all!) and especially since I know next to nothing about speaker design or electronics.
Actually that's a lie, I know nothing about speaker design or electronics.
The problem is I've been reading... lots and lots of reading. I've spent hours and hours, in fact days on Elliott's (ESP) website and at the same time I happened across the Statements.
So having lived a life of below average 'hi-fi' I always planned to buy myself a decent system at some point in my life and go 'all out' as much as I could afford. Of course as with so many other things in life and with the power of the internet I see that DIY is the way to go, making our money go further provided the individual is willing to put the effort in!
So here is the plan, note that there are a lot of bits still not ironed out and this will initially concentrate on the front pair of Statements to be used in a HT setup but at the same time, has to be good for music.
Each 'Statement'(?) will be cast from concrete, yes yes I know, it's insane, it's impractical and they'll weigh a freaking tonne (each) but I've always liked the idea of a virtually inert cabinet material which doesn't need all the extra bracing internally. Apart from removing the unnecessary bracing the cabinet design will remain identical (internally at least) unless otherwise advised.
Each Statement will contain:
ESP P09 - 3way crossover with balanced XLR input, directly connected to...
3x ESP P101 - Three power amps, low power version. Possibly use P03A's to reduce the cost per speaker.
And throw in the necessary power supply(s) for it all (P05B?), soft-start and muting circuits (P39 and P111?).
I realise I'm probably massively over complicating things, especially since I don't have a clue and how much will certain things make a difference? Who knows, building them out of concrete is just my time and I'd have to spend just as long learning wood work as I would pouring concrete.
Having the amps directly connected to the speakers I was trying to work out whether or not they should still be connected in series or parallel to keep everything in balance.
As for the rest of the system, the centre will be the Statements Centre and I'm not sure whether or not to go for Mini Statements or Monitor Statements for the surrounds.
The subs will be IB subs, either a 4x15's, 2x2 of 18's or 2x4 18's all in a line array, driven appropriately and tied into the main system. This has yet to be figured out on the IB cult forum but I see ThomasW is actually part of this forum!
This will all be driven by either a Marantz AV7005 Pre/Pro (7.2) or if budget allows an Integra DHC-80.3 Pre/Pro (9.2), fed by an HTPC bit streaming to the Pre/Pro.
A lot of good things are said about:
The Statements
Active crossovers
Tri-amping
Concrete enclosures
IB subs.
So I wanted to put them all together and see what I got. Overkill? Maybe, but I'm open to your thoughts/suggestions/changes/criticism/anything and I sincerely hope that Curt/Jim do not take offence on my suggesting doing the already brilliant Statements differently.
I figure going 3-way active crossover with 3xP101's will push the cost of *each* Statement >$1000, as for the Mini/Monitors I'm not so sure. Switching to P3A's should reduce the cost a lot and I'm not sure how much benefit would be gained from going to P101's anyway.
Packaging is also a concern, integrating everything into each speaker with 1xbalanced XLR input, 1xpower socket and managing all the heat that comes with it.
I want to go *low*, real low and loud as effortlessly as possible so to not loose control. I'm happy to use the IB subs with the Statements mains to back them up whilst listening to music as well.
Anyway, enough of my rambling.
The Statements
Active crossovers
Tri-amping
Concrete enclosures
IB subs.
I Agree with you that emulating the target acoustic response of the individual drivers is the way to go, but I think that it would be pretty hard to achieve unless one is provided with Curt's original driver measurements.
