Do all amps sound the same? VOTE!
  • Amfibius
    • 4
    After reading the other thread I thought I would post a poll to see what people think
    58
    Yes
    6.90%
    4
    No
    91.38%
    53
    Unsure
    1.72%
    1
    Show me the results
    0.00%
    0
  • whoaru99
    • 639
    No.
    One would be foolish to say ALL amps sound the same.
    BUT, many will be indistinguishable from one another when operated within certain constraints.
    I think the results of the poll would be more interesting if the question was rephrased to include some constraints. Such as being of competent design, similar type of amp, operated to the lowest common denominator of those being compared, level matched, etc.
    It's fairly obvious that a 100 WPC high end amp weighing 100lbs has an almost certain probability of blowing a 100 WPC receiver out of the water in a free-for-all matchup. I think the results COULD and MAY be much different when running them at "normal" listening levels requiring only a watt or two of power.
    ----JAFFE'S PRECEPT
    • wolfgang
      • 75
      That probably sums up my own experience so far. I've never questioned some amps might by be better then others. Until recently that is. After listening using my own ears with the SP level matched more closely I was amazed how little difference the sound appear to be when driving the same pair of monitors. The pricetags range from UK£600, £1500, £2500 and £5000. They probably cost the same in US$. All were around 100-150W per channels solid state designs. So I bought the cheapest which was a Rotel.
      I suppose the questions is what you wanted to do. If you are only going to drive the majority of loudspeakers with sensible load in an average size domestic living room then probably any competently design amps available nowadays are more then capable for the job. It would be interesting to listen to newer design like the Rotel RB1077 to see what is the state of play with this class D stuff.
      • jonathanb3478
        • 440
        I have experienced a difference when listening to an Audio Research 60w/ch tube amp vs a Parasound 60w/ch ss amp. I discuss the experience, and my thoughts on it back in 2003 here.
        EDIT: I preferred the Parasound, even cost no object.
        -Vernon Sanders Law
        • whoaru99
          • 639
          I don't doubt you, considering that tube amps and a SS amps are fairly different critters.
          ----JAFFE'S PRECEPT
          • Audiophiliac
            • 346
            Wow.....2 yes votes? I guess the forum is probably equal opportunity and must allow the hearing impaired in.
            • misterdoggy
              • 1418
              I'm sorry......
              The question is vague so anyone that would say yes with such a broad interpretation really must be from another planet.
              I mean how could ALL amps sound the same ?
              You couldn't possibly be an Audiophile and answer yes.
              • raider
                • 63
                I voted no as they really don't sound the same!!
                And the reason I have this opinion is when my amp is thermally stabilized and in its operating temperature range its smoother (particularly in the high freqs) then when its first turned on (cold)!
                IMHO i think all solid state amps react somewhat the same way but with different results!
                It Is What It Is 8)
                • Arneson
                  • 240
                  Please let me add to your perception of this issue.
                  I voted no firstly, and I admit I am not an audiophile. I can never be.
                  I was the one always right up near the stage at rock concert, often directly in front of sound system.
                  The DB level has knocked my ears into a narrow spectrum.
                  So like that ring tone that only kids can hear, I would never be able to tell any difference of sound quality from any amp.
                  I could see the difference on a scope and monitor the difference with a spectrum analyser, but I would never hear any difference.
                  • wolfgang
                    • 75
                    Annoying geezer oke: Audiophile
                    VERY INTERESTING POLL
                    • Amfibius
                      • 4
                      44 "yes" votes
                      2 "no" votes
                      1 "unsure"
                      Well I guess that settles it. The majority of this forum think that amplifiers sound different. No more need to debate the subject I think.
                      • whoaru99
                        • 639
                        Originally posted by Amfibius
                        44 "yes" votes
                        2 "no" votes
                        1 "unsure"
                        Not necessarily. It only addresses the question of ALL amps sounding the same.
                        By the same token, 2/3 of people taking my poll indicate they have not tried a level-matched, blind test which eliminates many biases about the sound of a component; regardless whether or not they are intentional or unintentional biases.
                        ----JAFFE'S PRECEPT
                          Poll: The DVD Release Threads
                          by David Meek
                          Do you want me to continue posting the weekly DVD release listings? Please vote in the box above.
                          Yes, continue
                          100.00%
                          25
                          No, not interested
                          0.00%
                          0
                          What's a poll?
                          0.00%
                          0
                          26 April 2005, 12:56 Tuesday
                          simple poll
                          by Andrew Pratt
                          Just wondering who our membership thinks consistantly puts out a quailty receiver line year after year?
                          I'll vote for Denon given the hugely popular 3200, 3300 and now the 3801.
                          21 March 2001, 09:40 Wednesday
                        • PiDD
                          Rotel 1098 Function knob preference poll
                          by PiDD
                          Please take the time and cast your vote!
                          Here is the issue. A recent SW upgrade puts a delay in the function knob. This really comes into play when I am labeling inputs.. as five clicks forward only takes me 4 places. (when I move the knob fast)
                          This really drives me...
                          Yes it drives me crazy!
                          42.11%
                          8
                          No I like it!
                          10.53%
                          2
                          They changed something... I didnt notice!
                          47.37%
                          9
                          19 July 2005, 14:00 Tuesday
                        • Bing Fung
                          Bi-Amp My Mains Poll
                          by Bing Fung
                          I have 2 extra channels on my 1095 and was thinking of Bi-Amping my B&W 603 S2 Mains. If I were to do this, how should I dedicate the amplifiers?
                          1080 to the Mid/Highs
                          1095 to the Bass
                          Or Vice Verse?
                          It will be a pseudo Bi-Amp :B
                          Yes! More Power, Just do it!
                          55.17%
                          16
                          Yes, but only if you do it properly with XO's before the Amps
                          13.79%
                          4
                          No, the extra amps will ruin the balance you now have, and besides, your wimpy speakers can't handle all that power...
                          0.00%
                          0
                          Just Settle down and enjoy the system as it is, let those spare Amps be lazy
                          31.03%
                          9
                          27 July 2004, 15:47 Tuesday
                          Interesting internet/movie poll
                          by Andrew Pratt
                          I came across this poll on the www.canoe.ca site (Canadian daily newspaper site) anyway it asks would you download a movie on your PC for $3.49? so far its leaning toward no but this brings up some interesting ramifications for our beloved hobby.
                          http://cgi.canoe.ca/htbin/survey/survey?poll=jampoll_jan1901a&resultsonly...
                          18 January 2001, 22:46 Thursday
