I recently started to hear a "pop" like when you turn the system on, or you plug to any AV system... witht he audio ON...this happen when the System is ON but no matter the Input..it could happen when is coax signal or Optical signal...
is not often.. sometimes 40 min or more... but is starting to anoy me
It is not a ground loop either coz i don“t own Ground on my room...
is weird, coz the only thing i change was the RCA Cable from my PC to the Reciver... It has a 2feet cable before and i changed for a 5 feet one.
At first i though it was the cable but then i was watching a Movie with a Coaxil Input on.. and the pop did it as well... the PC was even turned OFF.
is posible the cable alone is doing this? even when the PC is not ON and the Active input is other than the PC cable?
