What's in a tuner?
  • Parsonsk
    • 101
    What's in a tuner?
    I've been looking at buying a Rotel tuner RT-1080 but at $750 CDN it seems that there might be better options out there!
    My only beef is that i'd like the system to match.
    ...But what makes a tuner worth so much and is it worth it? I can buy other brands for a third the cost so why would i spend this much money just so my system matches?
    Please, don't tell me to trust my ears and listen for myself, that's such a wimpy way out!
  • Rolex
    • 386
    Well, it's true, every tuner is going to sound different and you have to trust your ears, otherwise, why would you buy a tuner? However, better tuners are able to pull stations from farther away, and some are better and "separating" the channels. I believe it is called selectivity. If you have a large city with many stations close together, not all tuners can separate those stations enough to pull in a clean signal. It all depends on your antenna as well. The area you live in is going to play a large roll as to whether or not you want selectivity or sensitivity for long range stations. Magnum Dynalab does excellent research on tuners. If you want to read more, go to www.fmtunerinfo.com for a lot of info, espeically on some older tuners.
    • hifiguymi
      Rotel's new tuner - the RDG-1520
      by hifiguymi
      Here is info on Rotel's new tuner. It's expected to be available in November, maybe late October, and retail for $999.00US.
      Sounds pretty cool.
      Eric...
      04 September 2009, 12:51 Friday
    • El Capitan
      1055 Tuner Problems
      by El Capitan
      My 1055 is giving me trouble with picking up stations higher than ~100.0 on FM.
      I have tried both my roof mounted antenna and the simple dipole that comes with the Rotel with the same results: it doesn't pick up these higher stations, and in fact, it will lock onto some station of a...
      19 July 2004, 21:42 Monday
    • greenjudas
      What do I need to know re:tuners?
      by greenjudas
      Hi everyone,I am waiting on my Rotel RSP1066 pre/pro to arrive soon and since it doesn't have a tuner,I would welcome any advice on what to look for when buying a tuner.It will most probably be bought 2nd hand.Will,for instance,the Rotels learning remote [1050] be able to be programmed to work a tuner...
      09 April 2005, 19:15 Saturday
    • Ut Pictura
      Rotel Tuner RT-06
      by Ut Pictura
      Haven't found any threads about Rotel DAB Tuner RT-06.
      I have a Rotel RA-03 amp and RCD-02 cd player, with B&W 603Ss. Wanted to know what the experience has been with the above tuner - it is quite a lot more expensive than quite a few other brands, and I did read one complaint about...
      06 June 2008, 21:28 Friday
      tuners
      by Andrew Pratt
      The topic of tuners came up over in the outlaw club regarding the new pre amp and I've never used the one in my Denon recevier. So in your oppinion is the inclusion of a tuner a must have or a waste of resources? For me I'd sooner not have it since the only time I listen to the radio is in the car as...
      30 May 2001, 10:35 Wednesday
