Power Conditioners Level 2 upgrading to Level 4
  • Colin47
    I currently have a Monster Level 2 power conditioner. The improvement in both sound and picture quality were worth the money. I'm thinking that if level 2 conditioning helped, level 4 would also be worth the money. Is this wishful thinking?
  • hidefdvd
    • 60
    Make sure where you buy has a good return policy and pick one up and see what happens.
    • Victor
      • Apr 2002
      • 338
      Absolutely! Power conditioning units have dubious utility, because the use of power conditioning presumes that your local power company somehow delivers ‘dirty’ power to you. It is simply not so. Also, a power supply in your hi-fi gear will reject the noise your are so concerned with anyway.
      …regards
      Victor
      • Kevin Haskins
        • 226
        No really.... most AC line noise is created inside the house. Things like computers, refrig, florescent lights etc....
        Power conditioning is a rather vague term also. Most commericial units break down into three catagories.
        #1. Simple RFI filters & surge supressors (VOMs). They filter RFI which is a significanltly higher frequency than the AC 120HZ power signal. They work just like a speaker crossover using inductor/capacitor networks to present high impedance to the RFI but low impedance to the 120HZ waveform. These types of devices are in the lowest cost type of filter units on the market. Simple IEC based ones can be installed that cost as little as $20 each but typically range in cost from $20-$300 range depending on the amount of pixie dust used.
        #2. Balanced Power Transformers: These cost a little more but provide different features. I'm not going to get in to the nitty gritty but the balanced power transformers split your incoming 120V line signal into a -60V & +60V rail. There is still a 120V difference so it provides just as much total voltage potential but doing this provides additional noise rejection. These cost much more because the transformers needed are large/heavy and use LOTS of copper.
        See here for more information: http://www.equitech.com/faq/faq.html
        #3. Power reconditioners AC waveform regeneration: These are expensive devices that take the AC waveform and convert it to DC and then back again to AC to get the cleanest possible AC waveform. They are expensive & power hungry because there is a lot of waste in the process. I don't recommend them because of the inefficiency and waste and it's ecological impact. Good balanced power systems are just as good in my opinion. This method is not only the most expensive initially but the devices consume so much energy that they end up being several times more expensive than balanced power units over the long haul.
        • Adz
          • Jan 2004
          • 549
          Kevin
          I believe the Equi-tech product line works similarly to the Monster Power conditioners such as the popular HTPS line -- Are there differences?
          Adz
          • Kevin Haskins
            • 226
            I don't know.... the Equitech shows what is used inside. I've never had one of the Monster units apart so I don't know the details. Furman makes a reasonably priced unit also.... they use custom Plitron transformers. Furman has a great engineering staff in the pro-audio market. If I was going to buy a balanced power unit I'd probably go with the Furman unit simply due to their engineering experience and reputation in that specific market. Monster has the resources to design good products but their marketing department is probably many times larger than the engineering dept. ;-)
            Parts Express sells the Furman unit for around $1200 or so.
            • sonicbaer
              Power conditioners...??
              by sonicbaer
              I know this subject seems to get out of control and I'm not trying to start any trouble...I don't want to be exiled ..I'm just getting started..
              My dealer was kind enough (I think) to lend me some Transparent power connectors...when I connected them in place of my OEM cables, I think...
              17 July 2006, 00:20 Monday
            • boothbrave
              anyone using power conditioners?
              by boothbrave
              Anyone use power conditioners with their gear ? Do you think they're overpriced or even worth it ?
              I heard amps should be plugged directly to the wall instead of these pwr. conditioners. Any reason why ?
              11 March 2003, 20:52 Tuesday
            • Joelp
              Power conditioners for HT gear?
              by Joelp
              HI all,
              I've been wondering as of late as to the effectiveness of power conditioners for home theatre equipment. For me it would be for my Receiver, DVD player tape deck, VCR, Sub and TV. I wonder though, are these AC line conditioners really much better than a $50 computer surge protector....
              26 November 2004, 17:04 Friday
            • miket
              Power Conditioners for Europe?
              by miket
              Any news about possible power conditioners (RLC-1040, RLC-1080) for the european market? I'm wondering why Rotel is sticking with the US market only. For a few hundred euro I'd be more than happy to add a rotel power conditioner and surge protector to my hifi plus have somewhere to connect all those...
              21 April 2008, 10:11 Monday
            • Blindamood
              New Rotel Power Conditioners
              by Blindamood
              I don't think this has been posted yet...just noticed that Rotel now has information about their new (APC rebranded) power conditioners on their web site:
              http://www.rotel.com/products/accessories.htm
              Kinda funny that they don't mention them on the 'what's new' area of...
              08 April 2006, 12:00 Saturday
