Long cables - line level vs. speaker???
  • whoaru99
    • 639
    I see that many high-end companies recommend putting the amps close to the speakers and having longer line level cables versus longer speaker cables.
    To me, this seems just backwards. Isn't it more likely that a long line level run has the possibility to degrade the signal more than a long speaker run?
    For a frame of reference, I'm talking 25-30 ft lengths...
    Todd
    ----JAFFE'S PRECEPT
  • Kevin P
    • 10812
    I agree with you. It's better to have short interconnects to the amps, and longer speaker wires, than the other way around. Low level signals are affected more by noise, interference, and cable capacitance than high (speaker) level signals.
    You could go the long interconnect/amp near speakers setup but long interconnects of the quality required would be far more expensive than the equivalent length of speaker wire.
    • Leef DaLucky
      • May 2003
      • 185
      I'm thinking this may only apply to balanced XLR interconnects?
      Many of the reviews seem to indicate they are stabler and shielded a lot better than typical longer rca runs.
      I wouldn't want to see the price tag on a good 30 ft run of XLR though.
      cheers,
      Mikey
      "...Because Good is Dumb...!"
      -Dark Helmet
        • 16183
        Hmmmm. I think at best, one has to say, YMMV. For example, I run balanced output from my preamp, and the electronic crossovers which are going back into my system soon are balanced output with low impedance tranformer drive.
        Most standard solid state preamps, even CD players, have pretty low impedance outputs (under 50 ohms), and driving 20-30 feet of a good set of interconnects shouldn't be too difficult. Now, my Cardas Golden Reference speaker cables are about as low a signature as I know of (AWG = 5.5; braided construction cuts inductance drastically compared with standard constructions), but the simple COST to buy a 20 foot set would turn what hair I have left white.... an 8 foot set was bad enough...
        Then there's the matter of which is easier to route or hide...
        Maybe it's a decision that should be considered carefully for each installation and it's requirements...
        ~Jon
          I'm an member of the long (fully shielded 2 conductor, but not necessarily fully balanced) interconnect and short speaker wire school of thought. :T
          • whoaru99
            • 639
            Hmmm...
            It sounds like a test is in order.
            I don't have immediate access to 30-ft interconnects of very high quality. But, for my powered sub, I made an RCA interconnect with Belden 8760 - specs as follows
            Nom. Characteristic Impedance 60 Ohms
            Nom. Inductance .18 µH/ft
            Nom. Capacitance Conductor to Conductor @ 1 KHz 24 pF/ft
            Nom. Cap. Cond. to Other Cond. & Shield @ 1 KHz 44 pF/ft
            Nom. Conductor DC Resistance @ 20 Deg. C 6.5 Ohms/1000 ft
            Max. Operating Voltage - UL 300 V RMS (UL AWM Style 2092)
            Max. Recommended Current 5.2 Amps per conductor @ 25°C
            I wired the cable using a "balanced" connection scheme (one conductor for center pin / one conductor for ground / shield connected to the ground only at the source end). I do understand that with RCA it's not really a true balanced configuration, but you get the point.
            My speaker cables are no-name 12-ga fine strand OFC.
            I have enough of the Belden wire to make a second interconnect in short order. Is the quality of the cables described sufficient that I could expect a meaningful result of the test? In other words, sufficient quality to even be worth the effort to test?
            Thanks again.
            Todd
            ----JAFFE'S PRECEPT
              • 16183
              This Belden is good for making a reasonable basic cable. Without knowing more about your system, it may be all you ever need. The most important point, IMO, is that you're using a dual wire configuartion with shield connected only at one end. This is the best unbalanced configuration, EXCEPT for Video and digital SPDIF signals, where you need a high grade coax with a characteristic impedance.
              You might find improvements using a cable with teflon insulated individual wires, and with a heavy braid shield, instead of just metalized plastic (Beldfoil). For a subwoofer application, the dilectric properties of the insulator are not very critical; this seems to become more a factor in the upper frequency ranges.
              Remember, the important thing for YOU to determine is what works for you in YOUR system, at the price you're willing to pay. And that's why I started off wtih YMMV....
              • terry78
                Long Interconnects and Rotel
                by terry78
                Has anyone used really long interconnects (about 25 feet) with the RSP-1066? I'm thinking of adding an RB-1050 and a pair of center rear speakers to my RSP-1066/RMB-1075 combo to get a full seven channel system. I could put the new amp back by the speakers and use a 12 year old pair of Straight Wire...
                21 May 2003, 16:05 Wednesday
              • joe_s
                Long interconnects vs long cables for 802d/803d
                by joe_s
                I will need to choose between long (about 60 feet) interconnects (balanced) between the pre/pro and the amp with roughly six feet speaker cables or alternatively short interconnects (a couple of feet) with about 60 feet of speaker cable from the amp to the speakers. The speakers in question will...
                11 March 2005, 15:21 Friday
              • Relentless
                Long interconnects or long speaker wires?
                by Relentless
                Well it's amp time for me finally. I have my eye on a pre-driven Boulder 2060 or a pair of Krell 750MCX mono's. Neither will fit on the rack so my choices are to place them next to the rack or the mains. So on to my question.....will I be better off with 6' interconnects and 18' of speaker wire or...
                07 March 2008, 03:54 Friday
              • jazznsoccer
                Which cables to have longer XLR or speaker?
                by jazznsoccer
                What is the better trade off - having a good stereo amp close to the pre/pro and having longer speaker cables (~20 ft) or putting monoblocks at the speakers and running long XLR cables (~20 ft) from the pre/pro?
                The center and surrounds and rears will have to do with 12 AWG zip cord....
                01 May 2004, 14:32 Saturday
              • titan7
                interconnects, Speaker wire, surge protection
                by titan7
                I have spent the last 3 hours researching interconnects. I currently have M.....r i300 mkII, 1 meter =$30. I thought these were ok but I have read so many review with half saying high priced cables are a waste and others saying it's not. I planned to stay at no more than $50-60 for a 1 meter cable....
                31 December 2005, 04:06 Saturday
