Project 1.2 set-up help
  • Anton
    • Oct 2004
    • 75
    My 1.2 and Phono Box have been out of action for awhile now and I want to get back into my LP collection. The sales guy I bought it from came to my place and helped me set it up the first time, he has now moved on and I'm sure all the moving around I have done with it since then has changed all the careful adjustment he had made. It’s fitted with an Ortofon OM 5E (that came with it right out of the box). The instruction booklet is a good guide to help me set it up, but I’m sure there is more alchemy then chemistry when it comes to these sorts of things.
    I don’t have any other set-up tools other then what came with the player.
    Any suggestions would be much appreciated. :B
    Canadian heart, Aussie home!
    Karl, you can go waayyyyy off the deep end into TT/arm/cartridge set-up if you want - read that as $$$$$$.
    A few things you can do without much, if any, costs are:
    1) make sure the shelf and platter are level - not close, level
    2) make sure you have enough oil on the bearing
    3) check the belt for wear or slippage when in use
    4) check the arm mounting screws and make sure they are snug
    5) make sure the cartridge is snugged to the headshell
    6) make sure the headshell is snugged to the arm
    7) make sure the wires/clips are all solidly connected - be careful, these are delicate
    When I say snug, that does not mean as tight as you can get them!
    Now, we'll start spending a little cash:
    To adjust the stylus I recommend having your dealer do that unless you are fairly proficient with your hands and don't get frustrated with tiny, detail-type work. If you still want to do it, you should get the following: an alignment tool (Pro-Ject makes their own for $99) and a tracking force guage (Shure's SFG2 is about $20). The Pro-ject tool will step you through everything you need to properly align your stylus and the force guage will keep the pressure on the stylus and vinyl in the right range for your system.
    If you want to get more detailed we can....
      Here's a link to the Pro-Ject alignment kit.
      • Anton
        • Oct 2004
        • 75
        Thanks for your help David, think that the alignment kit is a must so I'll get one asap.
        • markyboy56
          can the benq 2050a projector
          by markyboy56
          hi
          do 180 to 200 inches at 11feet throw distance that is the depth of my room and still have a fantastic picture without altering the brightness light ambience
          is there anthing that can be altered to do this
          thanks kindly...
          04 February 2019, 18:03 Monday
        • kiko
          Looking for new cartridge + stylus - Help appreciated
          by kiko
          Hi everyone
          I am shopping for a new cartridge + stylus for my turntable, or so I think. I currently own an entry-level Stanton T50x turntable bought 5 years ago when I wasn't too sure going back to vinyl would be as exciting and feasible as it is now. I run that Stanton through a Yamaha...
          11 September 2010, 09:31 Saturday
          DIY Turntable project!
          by Hdale85
          Being as these forums are my home and I like to contribute with what I can I have decided to post all the info pertaining to the turntable I'm planning out and going to build.
          All my friends have been getting turntables... So I decided to start planning out my DIY turntable. This is what...
          20 March 2008, 03:30 Thursday
        • JohnT
          Blasted grado stylus broke, any recommendations for replacement
          by JohnT
          I was listening to an album tonight and noticed it didnt sound right, I then noticed my grado needle was bent to one side, tried to straighten it but it just broke%*&@#..oh well, I now need a replacement and want to try something other then grado..
          I want a kickA@@ needle for not...
          23 February 2003, 21:53 Sunday
        • Susan
          Replacement Phono Cartridge/Stylus
          by Susan
          Can any of you recommend a a good cartridge/stylus discounter? I need to replace the stylus on my Sony direct-drive (PSFL-72 II) but the Shure site doesn't recommend a replacement model. I'd love to buy just a replacement stylus, but realize this may not be possible as the cartridge (N110HE Shure) is...
          01 February 2001, 03:44 Thursday
