Being as these forums are my home and I like to contribute with what I can I have decided to post all the info pertaining to the turntable I'm planning out and going to build.
All my friends have been getting turntables... So I decided to start planning out my DIY turntable. This is what I have so far of the base.
The holes that are in a circle will have a .5" wide .125" deep rare earth magnet in each. The blue line represents where the edge of the platter will be. The bottom of the platter will have the same magnets in it so the platter will levitate. There will be a pole in the center that goes up through the middle of the platter and creates the pole piece that the LP sits on. So the pole will hold the platter in place and the magnets will be the bearing. I'm still working on what I'm going to do with the electronics portion of everything as far as motor and how to control speed. I might just do a 1 speed only which would be 33 as I'm not sure I would actually get a 45... but I guess its possible. The base is 2" thick the platter will be either some hardwoods laminated together or a bamboo butcher block and would like to be 3-4" thick. The tone arm I'm probably going to build my self but still working out how I want to do that as well.
So let me know what you guys think and I'm very open to hearing idea's about how to control the rpm of the platter as well as tone arm ideas.
