Audio experts weigh in on this please
  • rick844
    • Jun 2019
    • 232
    Im confused. Either this guy is crazy or hes onto something. Please advise on your thoughts on this.
    I am quite curious
    • 1577
    I was just reading a thread about something similar at PE, except there they were coating the panels with watered down glue to stiffen them up a bit. I suppose anything can sound pretty good with enough EQ?
    For what it's worth, it did sound pretty impressive as far as Youtube videos go. I'd like to hear a system of exciters and panels sometime, just for grins. It's a fairly inexpensive project to set up.
      Okay.
      • rick844
        • Jun 2019
        • 232
        So, is this a gimmick or is this something that is a potential useful application?
          • 1044
          My take, and I'm far from an expert...
          • Different materials have different absorption properties (hey look! Columbus just discovered the "New World"!)
          • Owens Corning panels are pretty good at what they do (not cheap, though)
          • Diffraction matters (changing geometries and location of the transducer)
          • Multiple layers helps a lot (welcome to constrained layer damping
          • Rigid foam is Good Enough for small drivers
          The pile of horse manure? Pay attention to that room. In the grand finale it looked like he was in a Mark 1 Mod A steel shell commercial warehouse. The acoustics would be terrible for the floor reflections, but if you lifted the drivers high enough, then basically anything would sound "open an airy" -- because the room is open and airy. That's it from my curmudgeonly Sunday.
          Yeah, and then there's that DSP thing...
          • Kal Rubinson
            • 2109
            I am quite curious
            https://m.youtube.com/watch?v=CKIye4RZ-5k
            I didn't see the OPs reference because I don't do UToob, so I am inferring what it shows from your post. Coating the side edges of OC panels is a common practice to add physical stability with minimal (but measurable) impact on absorption. Painting it on the major surfaces (front/back) is sometimes done with the intent to reduce HF absorption in situations where there is a requirement to use so many panels for adequate MF/LF absorption results in unwanted dulling/absorption at HF. Some vendors add a thin skin for a similar effect.
            Kal Rubinson
            "Music in the Round"
            • rick844
              • Jun 2019
              • 232
              Wut? Im only asking if this is something worth looking into, or is this just a joke.
                • 1577
                Yup, you nailed it! Have you seen applications where these are actually in use?
                Well the title of the video is certainly clickbait - these are not the world's best speakers by a long shot and really should not replace anything in the home. I could see something like this being used commercially for sound reinforcement, maybe (like in a Wal-Mart or similar). It'd have to be cheaper than readily available alternatives though.
                So, it's a 'joke' in that the title is misleading, it's not a joke in that exciters really exist; Dayton makes several. Worth looking into for home use? Probably not unless you like tinkering for the sake of tinkering.
                • rick844
                  • Jun 2019
                  • 232
                  Thats exactly what i was asking. Is this for real, or is it a waste of time. Click bait? Not sure what you mean. My original qiestion was, is this something that should be considered, or is it a waste of time
                  Sheesh.
                  • Norm
                    • Mar 2011
                    • 62
                    Hi rick844,
                    The author of the linked YouTube video is not crazy, but also not onto the ‘world’s greatest speaker’ breakthrough he touts.
                    I often refer to the Alice in Wonderland rabbit hole metaphor commenting “that rabbit hole is a deep one” when discussing the branches technologies take. In HiFi speakers there are rabbit holes labeled “cone drivers”, “horns”, “electrostatic”, and “planar magnetic”. This rabbit hole would be labeled “distributed mode”. Unlike most of the others distributed mode loudspeakers (DML) do not attempt to get the vibrating membrane that is producing the sound to move like a unified piston tracing the electrical input into a mechanical analog. Rather DMLs encourage the radiating diaphragm to behave chaotically vibrating more like the surface of a pond rippling in response to a rock thrown into the water. Except in this case the rock is the exciter and the pond’s water is the diaphragm material. This is one of those interesting cases where something engineers spent decades achieving (rigid piston like diaphragm motion) is abandoned and what is usually considered a source of distortion (cone breakup) is encouraged as the preferred mode of operation.
                    DML may be a relatively new term but the idea is anything but new. When I was a freshly minted audiophile in the 1970s a South American firm Bertagni enjoyed some commercial success with their DML speakers using Styrofoam diaphragms.
Name:	1096124-bertagni-electroacoustic-systems-bes-sm100-speakers.thumb.jpg.04ec3a0f5e6c4be57d42e3c0cce1f71a.jpg
                    Bertagni speakers, grills off
Name:	1096123-bertagni-electroacoustic-systems-bes-sm100-speakers.thumb.jpg.97e22c40f1b2816529a9f3a8a5c8051c.jpg
                    Bertagni speakers, grills on.
                    DML’s tend to radiate in a somewhat omnidirectional pattern, that and the mechanics of their panel + exciter architecture they often take the form of a panel speaker as seem in the Bertagni’s.
                    Bertagni and other early users of DML relied on cut-n-try design to determine how to shape the panels, materials to use, and where to clamp the panels and place the exciters. With exciters available from Parts Express and others this is a popular pursuit with DIYer’s. The depth of this rabbit hole can be judged by the 161 pages of posting at just this thread:
                    https://www.audiocircle.com/index.php?topic=70541.0.
                    By the turn of the century computer modeling of electro mechanical acoustic devices was sufficiently advanced to allow BMR’s to be modeled in CAD. Out of that research the now defunct NXT PLC (https://web.archive.org/web/20061221...ex.php?id=home) was founded to advance and market the technology. Details here:https://en.wikipedia.org/wiki/Distri...de_loudspeaker
                    Presently the Tectonic Elements’ (who ended up with NXT’s IP) drivers are the starting place for DIY efforts:
                    For really high-end use the German company Gobel High End is the primary BMR user I am aware of. The rectangular carbon fiber panel seen in their Epoque line models is their in-house produced wide range BMR.
                    Manufacturer of ultra high end speakers and high end cables based on patented bending wave and cable technologies. High end loudspeakers made in Germany!
                    In conclusion “World’s Best Speakers!”?? No. Interesting rabbit hole, yes.
                    Last edited by theSven; 26 March 2023, 11:19 Sunday. Reason: Update image location
                      • 1577
                      Norm,
                      Thanks for showing some real world samples, I had no idea these were actually used in hifi. Very interesting rabbit hole indeed.
                      • rick844
                        • Jun 2019
                        • 232
                        Originally posted by Norm
                        Hi rick844,
                        Thank you for taking the time to explain and add value to my thread. Your response was very informative and has sparked my curiosity a little bit, especially since in some of the examples you provided, seems to provide insight as to who may also be using this method. Also the rabbit hole analogy made perfect sense.
                        Hopefuly some of the others on this forum can gain from your input as i will.
                        Thanks again.
                        Last edited by theSven; 26 March 2023, 11:20 Sunday. Reason: Update image location
                          I think any of these panel technologies has promise for certain applications. I'd imagine that they can be made to work to reasonable levels of fidelity too but they are still limited by the laws of physics. You'll need insane displacement capabilities to reach decent, low distortion, SPLs in the bass. I can't see this happening. But then maybe that isn't the intended application. Get down to 100-150Hz and use a sub.
                            • 1577
                            IIRC, Adire Audio tried doing a sub like this back in 2005 or so. I know they had a video but I can't seem to find it now. The thing looked dangerous, had an xmax of several inches operating in open air. I don't recall what the panel material was, but it certainly wasn't made from a drop ceiling panel!
                            • mlammert
                              DIY Acoustic Panels - "Transparent" Fabric Question
                              by mlammert
                              I am getting ready to build some DIY acoustic panels for my listening room. I am building 5 of these panels; one for a ceiling cloud and two on each side wall (one for first reflection point and one for second reflection point on each wall). I have tested this by hanging some blankets and quilts at...
                              11 February 2018, 22:10 Sunday
                            • springer49
                              Question for the B&W experts. SCMS-1 or 805S
                              by springer49
                              My brother is putting together a home theater and I was hoping to get some opinions from the experts.
                              SCMS-1 or 805S for the rear speakers.
                              They will be very close to the seating area. Pretty much at ear level or slightly above and within 1-3 feet of the listener.
                              He has been trying...
                              16 April 2007, 19:06 Monday
                            • bambrose
                              Different plasma panels
                              by bambrose
                              I'm now looking into a 42" plasma monitors for my system (I need some of my living room back). I'm looking into the tecnology end and I'vr noticed that some panels use the ALiS tecnology. These panels supposedly give you more resolution and better brightness by getting rid of the horizontal...
                              03 July 2003, 13:07 Thursday
                            • Mazeroth
                              Last minute advice on my OC 703 panels?
                              by Mazeroth
                              I just purchased a case of 12 OC 703 2" panels from a local supplier (me = pumped). As it stands I'm going to be making 12 panels for my listening room. They are the unbacked 703 panels. The plan is to make some frames for them using something like 2"x1" boards and the frames will...
                              16 September 2006, 19:06 Saturday
                            • dmccombs
                              800 Series need ceiling acoustic panels?
                              by dmccombs
                              I have added bass traps in the corners of my room and I have panels on the side walls for 1st reflection points.
                              In my reading, I have seen that some speakers are aided by the use of panels on the ceiling. The info indicates that speakers that have tweeters with a high range of...
                              23 March 2007, 15:56 Friday
