Last minute advice on my OC 703 panels?
  • Mazeroth
    • 422
    I just purchased a case of 12 OC 703 2" panels from a local supplier (me = pumped). As it stands I'm going to be making 12 panels for my listening room. They are the unbacked 703 panels. The plan is to make some frames for them using something like 2"x1" boards and the frames will have an internal size of 24x48, the size of the panels. I was then going to use peg board on the back, but only in the corners, to provide strength and let "some" of the waves through. The peg board corner pieces will be cut into triangles and will be roughly 8"x8". Does this sound ok so far?
    Now, on to covering them. I've read that I should use a low thread count material, that is not dense, so the high frequencies won't bounce off them. Is this true? Basically, I'm going to go to Jo-Ann fabrics with my wife and need to know what I should be looking for. The cheaper, the better, as this is a pretty ugly listening room in our basement and we're only renting.
    Sorry if the grammar was bad but I'm getting yelled at to leave for dinner.
    Thanks! :T
    Any fabric will work well enough. Just pick one you and your wife like the looks of.
      Any woven fabric will be fine. Avoid Naugahyde or anything like the red/white checkered oil-cloth used for table cloths in 1950's era diners...:wink:
      • Mazeroth
        • 422
        Thanks guys.
        Also, I was just going to hang them on the walls but I see that if I leave some space between them and the wall that the low frequency absorption will be improved. The chart I was looking at (link below) has measurements with the panels 16" out from the walls. My listening room is only 11x17x7 so having the panels sticking out 1.33 feet isn't going to work. Do you think there will be some noticable improvement if I were to have the panels stick out 6-8 inches?
        Lastly, I was thinking of putting some bass traps in the back of the room and was wondering if this methodology would work. I was going to cut one piece of 703 in half and make the same frames, only the bass traps would be 2 feet by 6 feet, utilizing a full panel and one half in each. I was then going to place these in the back corners at a 45º angle, which would give me a triangle that measures 17x24x17, where the 17" is the length of the side walls where the panels would attach. My ceilings are 7 feet tall so I would place this 6 inches off the ground and 6 inches from the ceiling. Do you think this would help with the low frequency of the room? Should I do this with dual 703s so it's 4" thick?
        Sorry for going on, but I have one more question My basement listening room had exposed floor joists in the ceiling like a typical basement does. My wife and I bought some $1/yard fabric at Jo-Anns and hung it on the ceiling, for a MUCH better appearance that only cost us $40. The room was finished when we moved in minus the ceiling. Are the floor joists causing problems with my low frequency response? I've seen triangle corner acoustic pieces to tame standing waves and I would love to try something like that, only I really don't have a true ceiling so that would be a waste, right?
        Thanks for reading this! I promise I'll buy a house someday with a real listening room. We're fresh out of college and are saving money before we take the "plunge"
        • dynamowhum
          • 260
          Darn I really liked the 50s diner motif.
          • Amphiprion
            • 886
            Are 1x2's actually 2"? Or are they 1.75" or some such?
            I just helped a friend build a bunch of OC703 panels, but we ripped MDF into 2" strips so I don't know.
            • dyazdani
              • 7032
              They're actually 3/4 by 1 1/2...
              Danish
                The exposed joists will assist with the breakup of room modes so they're a plus not a drawback.
                For the 703 to function as a bass trap it has to be quite thick or built as a membrane trap. Those have a element like ply in the front of the insulation. Here are a couple examples
                More info here.......
                • Mazeroth
                  • 422
                  Thanks for all the help!
                  I bougt the wood supplies today to build them and will begin production of them this week. I'll keep you guys updated with pics and before/after measurements.
                  • mlammert
                    DIY Acoustic Panels - "Transparent" Fabric Question
                    by mlammert
                    I am getting ready to build some DIY acoustic panels for my listening room. I am building 5 of these panels; one for a ceiling cloud and two on each side wall (one for first reflection point and one for second reflection point on each wall). I have tested this by hanging some blankets and quilts at...
                    11 February 2018, 22:10 Sunday
                  • stuofsci02
                    My DIY Acoustic Panels
                    by stuofsci02
                    I have been working on my Basement setup for about 18 months now. It was an unfinished space.
                    Recently I decided I would build my own acoustic wall panels to take out the first reflection points, and tame the room a little. I thought the room already sounded great, but whoooaaaa, what a...
                    13 November 2011, 19:26 Sunday
                  • Marzen
                    Peg board wall for a bass trap?
                    by Marzen
                    I was wondering if a peg board wall with unfaced insulation behind it would work as a room deadening device and/or bass trap? I would have it flush with my L/C/R + sub speakers at 12'w x 7'h with a cavity 2' deep. I saw a similar idea using horizontal slats on a rear wall to reduce reflections but...
                    19 November 2006, 21:21 Sunday
                  • DIY_newbie
                    Both h-frames completed
                    by DIY_newbie
                    As promised..
                    2 Frames glued and screwed together. The left one has speaker spikes installed, I'm wating on a set for the right one. The mid/tweeter panels are still mocked up from cardboard, I'll start working on the MDF panels this week.
                    I've purchased some really nice Mohagony...
                    16 September 2005, 23:25 Friday
                    Acoustic fabric
                    by impala454
                    Does anyone have a "go to" source for acoustic fabric in building some panels? I'm looking for a fairly wide selection of preferably solid colors.
                    Also if there's any good advice on building panels that would also be appreciated.
                    09 September 2012, 07:58 Sunday
