Another Finalists build
  • Nordskov
    • May 2016
    • 24
    Hi everybody.
    I am about to start building a pair of Finalists by Jim Holtz and Curt Cambell.
    I currently run a pair of Dali Evidence 370 in which Im not satisfied. Not much bass, scooped midrange and aggressive highs. Actually I only run one as my son blew a woofer at a party this spring. A new woofer cost more than a second hand speaker 8O
    Its a leap of faith as I have never heard the speakers, but after reading lots of very positive reviews I settled on this design.
    Choosing the right design was tough. Theres a lot of good designs out there. I had four important goals; go deep, good midrange, not too big and affordable.
    Several design had my attention:
    Paul Carmodys Classix II, Amiga and Tarkus (too big)
    John Krutkes ZDT3.5 and SR71
    I even looked at some of Troels Gravesens designs but they are too pricey.
    Then I stumble across The Statements which are too big for my room. So is the Mini Statements, but The Finalists fit the bill perfectly.
    So here I am.
    My woodworking skills are above average. I know my way around a table saw but am not too familiar with the router. I never did a circular cut with it, so cutting holes may need some practice
    I tend to follow the design and use MDF board. I still havent decided how to make the finish. Veneer, white paint or maybe some coats of clear varnish.
    I just received the hardware from LoudspeakerFreaks after more than a month of impatience, only to discover I accidently ordered the wrong woofers. 4 ohms instead of 8 ohms, stupid! :evil:
    Unpacking stuff always makes me exited, I feel like a child at Christmas
    This is the first time I lay my hands on audiophile capacitors and man they are big!
    I had some questions regarding cabinet and cross-over which Curt was very kind to answer. One of them was about the resistance of the coils. 0.3 mH ~ 0.26 Ohms, 0.5 mH ~ 0.34 Ohms and 6.8 Mh ~ 0.29 Ohms.
    Disillusioned by the woofer mishap, I decided to lay out the parts for the cross-over having distance between coils in mind. I managed to cram it down to app. 15 x 20 cm.
    Now Im going to buy some wood and get going.
    I'll be back!
    New center channels for the Statements II and The Finalists!
    by Jim Holtz
    You can't have a new speaker without a new center channel to compliment it for home theater.
    Statements II and The Finalists Center Channel
    During the last several years the original Statements have been frequently used as mains for home theater systems. The original Statements...
    26 June 2014, 20:12 Thursday
  • Supernova
    Finalists - A gift build.
    by Supernova
    Hello all.
    I am getting ready to build a pair of Finalists for my father-in-law, Steve, as a 50th Birthday gift. His birthday is in August, but with kids and all it's hard to find the time and I'm currently prepping a space to build. He's a huge music fan, but has never owned a proper set...
    30 January 2018, 14:04 Tuesday
  • danman1
    The Finalists Mid Woofer substitute?
    by danman1
    Has anyone found a new driver that works as well as the original design?
    Or.. has there been a change that anyone knows of in the design of the crossovers that will work with changing out the NE149W-04 for the 8 ohm version since the 4 ohm is not available?
    Hopefully...
    15 March 2020, 17:35 Sunday
  • johngalt47
    Finalists cabinet question
    by johngalt47
    I can't read the cabinet drawing very well on Curt's web site. Is there a clearer drawing posted here or elsewhere on the web that I can get?
    02 August 2013, 15:07 Friday
  • Mandroid
    Slow Finalists Center and Anthologys Build
    by Mandroid
    So, I decided to build a couple of Jim and Curt's more recent speakers. PE has had RS225's and RS28F's on sale recently, combined with a bit of shopping spree action allowed me to get most of the parts I needed for very reasonable cost. As the title says, the build is likely going to be slow. I would...
    21 September 2016, 16:38 Wednesday
