Kirk's WTMW Center Build
  • kirknelson
    • 89
    I'm building the WTMW Center for use in a system with Khanspires as mains and NataliePs as surrounds. I began the build shortly after completing my NatPs and am building my Khans concurrently. I had a lot of fun and learned a lot while building my NatPs and couldn't wait to get going on my next projects. The quality of sound acheived by the NatPs really made me motivated to finish off the system.
    Freshly cut boards:
    Click image for larger version  Name:	IMG_0346.webp Views:	1 Size:	7.2 KB ID:	942769
    Glueing together the side panels and the Mid enclosure:
    Click image for larger version  Name:	IMG_0348.webp Views:	1 Size:	25.0 KB ID:	942770
    I chose to glue the braces together rather than cutting them out with a jig saw because it's easier :P and because it results in less wasted MDF. You do have to be careful to keep the ends even when putting them together. I used the floor as an end plate to keep them aligned and it worked well. When attaching the Mid enclosure the rear wall was to far into the interior for the clamps to reach, so I used a piece of scrap MDF as a bridge and placed a clamp on either end to apply pressure.
    Click image for larger version  Name:	IMG_0349.webp Views:	1 Size:	27.1 KB ID:	942771
    Click image for larger version  Name:	IMG_0350.webp Views:	1 Size:	26.0 KB ID:	942772
    Attaching the braces to the bottom:
    Click image for larger version  Name:	IMG_0351.webp Views:	1 Size:	22.7 KB ID:	942773
    Attaching the top:
    Click image for larger version  Name:	IMG_0353.webp Views:	1 Size:	28.8 KB ID:	942774
    Glueing the baffle pieces together:
    Click image for larger version  Name:	IMG_0352.webp Views:	1 Size:	27.2 KB ID:	942775
    Next up is routing out the baffle and waiting for my cross over components to arrive.
    You need 2 more clamps, 1 on each end.
    Just joking. You're probably fine. But on your next project, you might want to use some pieces of scrap wood between the clamps and the finish piece to help spread the clamping force out.
    I agree with you about just gluing the braces up. I've done it that way in a few places.
    I'm looking forward to hearing your impressions of the NatP's next to the Khans. I don't expect there to be differences in quality, but maybe slight differences in voicing for personal preferences between Jon and CJD - don't know. Just remember, everything is adjustable.
    • kirknelson
      • 89
      I'm back from my ship's exercise and it's time to do an update on my progress.
      Glueing the rear panel on:
      I sealed all of the cabinet joints with silicone to help prevent leaks:
      The front baffle is all routed up and looking good. I'll be giving it a 1/2" round over after it is attached to the cabinet:
      The camfered edges for the woofers:
      I also managed to get all of the crossovers wired up.
      Here's the Tweeter:
      The Mid:
      The Woofer:
      All of the joints tested great with the continuity tests on my multi-tester. I also hooked them up to the drivers outside of the cabinet to make sure everything was functioning properly. My apartment didn't burn down so it seems everything works great. Out of curiosity does running them like this pose any risk to the drivers?
      Up next: Veneering the cabinet.
      Unfortunately it will be delayed again due to my getting lasik surgery (can't explose my eyes to MDF dust for about a month while they heal) and more underway periods for my ship. I'm hoping to get them done before the holidays.
      Last edited by theSven; 24 June 2023, 23:36 Saturday. Reason: Update image location
        Welcome back. Looking good. :T
          • 16203
          Yeah, those cruises at sea can definitely cut into your available shop time! :W
          Looking good- you're making a lot of progress. Sometimes slow and steady is the only practical way.
            Just don't expect it to play loud - you can overdrive the woofers in particular quite easily that way.
            Your patience is about what you need to embark on one of my projects if the crossover hasn't been designed yet! I like it.
            • kirknelson
              • 89
              I think I missed taking pictures of a few steps, but here it is finished and put in place in my theater.
              Time to sit back and enjoy some movies!
              Last edited by theSven; 24 June 2023, 23:38 Saturday. Reason: Update image location
              • john trials
                • 449
                Very nice looking!!!!!!
                • kirknelson
                  • 89
                  Please see my Khanspire build thread for comments on the sound of this system.
                  Like the Khan's the WTMW ended up a little closer to the front wall than it is in the previous picture. This is an excellent center channel for the Khan's and I would recommend it for anyone needing a free standing center channel instead of placing the speaker above or below a TV like the khancenter is designed for.
                  Here is my BOM:
                  Code:
                  Parts Express
                  (1)1 Ohm Resistor		$1.25
                  (1)4 Ohm Resistor		$1.25
                  (1)5.1 Ohm Resistor		$1.25
                  (1)30 Ohm Resistor		$1.25
                  (1)0.25mH Inductor		$3.43
                  (1)1.0mH Inductor		$8.53
                  (2)0.5mH Inductor		$10.20
                  (1)4.7mH Inductor		$16.78
                  (1)100uF Capacitor		$23.43
                  (1)12uF Capacitor		$6.34
                  (2)10uF Capacitor		$11.54
                  (1)39uF Capacitor		$13.60
                  (2)4.7uF Capacitor		$6.44
                  (1)1.0uF Capacitor		$1.38
                  (1)15uF Capacitor		$6.26
                  (1)Dayton RS28AS-4 Tweeter	$55.87
                  (1)Dayton RS150S-8 Midrange	$35.19
                  (2)Dayton RS225S-8 Woofer	$104.96
                  (1)Dayton Binding Post		$7.89
                  Parts Express Total		$316.84
                  Big Box
                  MDF				$27.74
                  Gasket   			$2.42
                  Polyfill			$2.47
                  Veneer				$109.98
                  OC703 ($8.18 per panel)		$4.09
                  Misc. Consumables (Approx.)	$7.50
                  Big Box Total			$154.20
                  Project Total			$471.04
                  • royceb
                    Question about my NatPs
                    by royceb
                    Hello everyone. I have been an avid follower of this site for about 5 years now which inspired me to to do my first DYI build with the NatP design. They have been a pleasure to listen to since then. The are currently sitting in an 18'x13' dedicated HT room, powered by a Crown XLS 402 amp. Come September,...
                    07 April 2012, 20:28 Saturday
                  • rumatt
                    Summary of key information from the 3-way WTMW / TMWW thread
                    by rumatt
                    I have spent hours trying to wrap my head around all the information contained on the 3-way WTMW / TMWW thread. It's extremely hard to extract the key information because of a number of reasons: most of the updated designs occur somewhere deep in the thread, and the first post has not been updated...
                    23 September 2006, 13:13 Saturday
                  • kgveteran
                    Dayton WTMW center channel as LCR revisited 10yrs later
                    by kgveteran
                    So, i've moved twice in the last ten years, had to store my stuff (HT gear), and im finally getting back to rebuilding a new room in a new house, with a lovely new spouse. It will be 13'x19'x vaulted ceiling.
                    I built some HUGE bass traps called super chunks, they are 2'x2'x108",...
                    08 August 2016, 15:24 Monday
                    Hey, what are those clamps? Answered...
                    by ThomasW
                    Whenever I post pictures of a build showing the corner clamps I use there are many questions about what they are and who sells them.
                    Here are images of them from the speaker camp thread...
                    I've owned these for almost 20yrs and it wasn't until recently...
                    25 June 2009, 11:34 Thursday
                  • orbifold
                    One more "big thread" RS WTMW Center
                    by orbifold
                    Its getting warmer in VA finally!! Warm enough that I can finish gluing up the sections for my RS WTMW Center. The PE buy was waay back in 2006. Towers have been running for some time. But I'm posting at the start of the center build so I'll finish :B
                    Also, the plan is to do an integrated stand-rack...
                    25 March 2009, 19:48 Wednesday
