Mike's LCR Statement Build
  • Curt C
    • 792
    Originally posted by mikela
    Asi,
    This is something I have not condsidered. ops: This may be the forcing function that moves me toward crossover design on my DIY speaker journey.
    Mike
    At this juncture, I'd suggest you not worry about it too much until you audition it. If you find the center too bright, email me for suggestions.
    Vee Haf Zee Teknology!! :??
    Curt's Speaker Design Works
    • ahaik
      • Feb 2007
      • 233
      Asi,
      Mike
      Fortunatly we have Curt around :-y
      One day I may try a design too, been planning to do that, but life is waaaay to bussy
      at the moment.
      My guess is you will be very happy with it as it is, I just brought that point out of curiousity.
      Good luck,
      Asi.
      • mikela
        • Mar 2008
        • 98
        Asi.
        Yes indeed! :agree:
        Curt,
        Sage advice and a generous offer.
        Mike
        • FroDaddy
          • 274
          FroDaddy,
          These are for the large Statements. I have an SMX acoustically transparent screen and so will be using 3 identical Statements of the sealed variety in the same horizontal plane. If I had a flat panel situation or a non transparent screen then I would be building a Statement Center Channel. I have a Velodyne DD-18 which I will cross over to at 40Hz.
          Mike
          Thank you for the information, I am going to use your layout for my Statements. :T
          • mikela
            • Mar 2008
            • 98
            Well, I stuffed the first cabinet today and promptly ran out of speaker cable. I will mount the baffle tomorrow and should hopefully be listening to mono by day's end. :^x
            Mike
            Last edited by theSven; 17 August 2023, 00:22 Thursday. Reason: Update image location
            • mikela
              • Mar 2008
              • 98
              Finally!
              Well I managed to get the first cabinet up and running. I am currently listening to some classical music and I must say, even in mono, I am impressed. I have tried some AB'ing between the Magnepans in mono. One thing is certain, the Statements are way more efficient. It's too early yet to make any kind of real comparison. Just let me say that I am more than just a little impressed. Kudos to Jim, Curt, Wayne et al. :T Due to pressing prior commitments, I will be unable to finish the other boxes until sometime in September. :cry:
              Mike
              Last edited by theSven; 17 August 2023, 00:23 Thursday. Reason: Update image location
              • David_D
                • 197
                Congrats Mike!
                The build looks great.
                -David
                As we try and consider
                • mikela
                  • Mar 2008
                  • 98
                  Thanks David.
                  I am really looking forward to completing the other units. The sound is awesome as far as I can tell using it in mono and stereo (one side a Magnepan). I have been planning on going with a black piano gloss finish as I will be using these in a home theater. However, I ran across this. He used several applications of ebony stain on ebony veneer followed by several coats of Tung oil. I am guessing that I would probably have to add shims underneath the speaker flanges to keep the drivers flush with the baffle. I would use a less expensive veneer if I were to do it.
                  Mike
Name:	Ebony Veneer.JPG
                    Thanks David.
                    I am really looking forward to completing the other units. The sound is awesome as far as I can tell using it in mono and stereo (one side a Magnepan). I have been planning on going with a black piano gloss finish as I will be using these in a home theater. However, I ran across this. He used several applications of ebony stain on ebony veneer followed by several coats of Tung oil. I am guessing that I would probably have to add shims underneath the speaker flanges to keep the drivers flush with the baffle. I also would us a less expensive veneer if I were to do it.
                    Mike
                    Hi Mike,
                    I glad you're happy with what you're hearing. It'll get a LOT better with both Statements in stereo. :T
                    • mikela
                      • Mar 2008
                      • 98
                      Question: I am using these binding posts http://www.partsexpress.com/pe/showd...umber=091-1245 . I noticed that most folks assemble their unfinished cabinets and later disassemble them for finish. Will it be OK to tap the binding posts out in order to finish the cabinets or would I be creating a problem?
                      Mike
                        Mike
                        Hi Mike,
                        It won't hurt a thing. :T
                        • mikela
                          • Mar 2008
                          • 98
                          Thanks Jim!
                            Talk about an apples vs oranges comparison.... :B
                            • mikela
                              • Mar 2008
                              • 98
                              Yeah, yeah I know...this is really not the way to compare speakers. But it's what I got at the moment.
                              Please take the following with a grain of salt given the circumstances:
                              It is quite surprising how little I miss the right hand maggie in stereo. The sealed Statement clearly has fantastic bass response with the 8" Daytons and this comes across in stereo. In the upper registers the Statement is comparable to maggie in terms of "air", maybe even a little cleaner. Both speakers tend to dissappear in the room. I find myself able to listen to the music longer and louder without fatigue. Very preliminary unsubstantiated listening results. I can't wait to finish the other speaker but suffice it to say that would cause significant nonlinear distortion in the household at this point in time.
                              Mike
                              • PoorboyMike
                                • 637
                                Hey Mike, did you ever finish your Statements? Just curious how you think they sound behind the AT screen.
                                • mikela
                                  • Mar 2008
                                  • 98
                                  PoorboyMike,
                                  I finished a stereo pair and have been so impressed with the sound that I have put off finishing them so far. The third speaker just needs to have the baffle glued on and drivers installed. I am also a little cautious about the finishing process. That and we are trying to decide whether or not to keep the theater in the family room or blow out a wall and add a dedicated theater room (leaning towards the latter). I intend to build a false wall similar to this http://www.avsforum.com/avs-vb/showthread.php?t=1000388 using some SMX screen material that I bought a while back. I think as long as I can get at least 1 foot of clearance behind the Statements I should be OK given that the entire false wall will for the most part be AT. I also have everything for the Monitors except the .75 MDF.
                                  On another note, I just put a B&K Reference 70 in my system and can say that I have never heard sound this accurate. What a great match to the Statements. These speakers allow you to squeeze out whatever the electronics can supply. It's just hard to turn off the system and go to bed at night. I am also about ready to complete several monoblock Hypex UcD400 amplifiers to replace a Parasound 2105. So lot's of work to happen this year.
                                  Mike
                                  • jyqureshi
                                    I can has Statements: Another Statement LCR build
                                    by jyqureshi
                                    Hello everyone,
                                    About a month ago I started my quest for DIY speakers and a week later decided to build Statements, now finally things have started to come together.
                                    So here goes:
                                    Parts Express didn't have the 4" Titanium Driver, I'm also waiting for...
                                    04 April 2009, 19:53 Saturday
                                  • soundemon
                                    Bordeaux vs Statement 2 build
                                    by soundemon
                                    Hi All
                                    Someone please give me some advice please - I'm planning a build for this spring / summer, and its going to be either the bordeaux or the statement 2, full LCR.
                                    In the past I built a Full size statement LCR. i enjoyed the build and loved the speakers. quite honestly, they...
                                    22 March 2021, 08:19 Monday
                                  • soundemon
                                    Soundemons Statement LCR build
                                    by soundemon
                                    Hi All
                                    After building my Recession buster kit, I've been looking for the next step and The statements are the ones for me! A great many of my questions are answered in the multitude of other build threads (great job everybody!) but I had a few:
                                    - For the center, is there a design...
                                    05 May 2009, 09:11 Tuesday
                                  • soundemon
                                    Crossover for making an in-wall statement Center
                                    by soundemon
                                    Hi All
                                    I'm getting on towards finishing my HT room, which will have Statement LCR.
                                    https://www.htguide.com/forum/showth...ght=soundemons
                                    And I'm planning a false wall IB in the front of the room. The center, I have not built yet, but was planning...
                                    07 May 2011, 13:08 Saturday
                                  • Karma
                                    The "Pile" or How to Stack and Not Get Stuck
                                    by Karma
                                    HI All,
                                    Ordinarily I would not recommend stacking equipment. I can't tell you how many times I have lectured my customers against such practices. I have strong opinions against stacking.
                                    That said, my 6 month old bedroom HT system has stacked equipment and it works very well. The...
                                    27 April 2006, 07:56 Thursday
