RLP15 project
    Ah there we go! It's perfect now. And of course the coaster your wife must be proud? :B
    • nick77
      • 88
      Originally posted by HeatMiser
      I don't know about those specific dimensions, but that's the basic idea. I've heard "20%" used as a rule of thumb for how much apparent volume you can get back with generous stuffing (the kind of volume that comes in liters and square inches, not the kind that comes in decibels ).
      I agree the idea is not very intuitive; it might be helpful to know that it has to do with the fibers of stuffing absorbing heat energy as the air inside the enclosure is compressed. So the air tends toward a more constant temperature, behaving as if it were not being compressed as much as it really is - just like what would happen in a larger cabinet.
      That's a pretty crude explanation and I hope the resident engineers will forgive me. I can't pretend to know anything about gas physics, but it sets my mind at ease to know there's something in there that makes a bit of sense.
      Now that I am understanding the principle of fibre filling adding more volume with such a large enclosure will I benifit even more by pulling more stuffing out? I previously removed half. Thanks
        The only way to find out is to do it and see.
        Until this past weekend, I was probably also had a slightly overstuff box about the same size as yours. This past weekend, I emptied one of my subs and left the other one with probably 40% filled. They were co-located, so I could flip back and forth and try and judge the results. It wasn't blind, so I could be biased, but to me the one with lots of stuffing sounded a bit muffled, and had about 2db less power. It sounded like it went a hair deeper, but this could also be because the upper was muffled a bit. The empty box seemed to have fuller sounding bass. I should have gotten REQW out to verify, but it was already a full day of listening and so forth.
        I ended up compromising. I basiclly lined the inside of the box with 1-2" fibreglass. I just pulled the R30 apart until it looked about right. So, I guess I'm probably down around 10% of the volume being used by fibreglass.
        I like the results, but it was a very subtle change.
        • nick77
          • 88
          Ok I pulled the driver out cause the thought of too much stuffing was bugging me. My power tools have been idle for several weeks and I cant hardly stand it. I have a unused channel on my EP2500 thats driving me crazy. Have I caught something?
          • FlashJim
            • 145
            Oooooh yeah. In the car world we call it the "mod bug". The treatment is expensive and there is no cure.
            • nick77
              • 88
              K- I achieved the exact same results, at first I used r-30 in all its glory at about 5" thick thinking I would tone down this huge enclosure and the sound output was disappointing and muffled. Next I removed about half the stuffing and achieved a tighter sound and increased output. Now I took out about half again and the result is again a little cleaner and tighter and a little more output. Also very subtle difference. Moral of this story dont overstuff a big box.
              Do you think the wife would notice if I installed a 15" driver in the other end table and fed it 750 watts?
              • chasw98
                • 1360
                Theres is one way to find out! :T
                • FlashJim
                  • 145
                  Just use a coaster under that beer and she may not notice.
                  • Inu_Yasha
                    • 256
                    Ok, I'm thinking about doing my sub like you did yours, making it into an end table. A few quick questions.
                    1. How large is the actual box part?
                    2. What type of wood and finish did you use?
                    3. On the EP2500 did you have to add some type of filter for the sub?
                    4. Are you running the full power through the sub or are you just running half of the amp's power?
                    Thanks!
                    • nick77
                      • 88
                      Thanks!
                      1. 22x22x26
                      2. 3/4 mdf double wall and 2 braces with pine overcoat
                      3. No filter but considering fbq or deq for eq.
                      4. One channel at 750 watts and still have 1 channel open.
                      • nick77
                        SS RLP15 meet its match?
                        by nick77
                        The TC Sounds TC-2000 appears to be the match up to RLP. I am no expect on stats, can someone please tell me if this driver would be superior to the RLP or is the SS still the best buy in the $300 range? I still have a spare channel on EP2500 that I still need to fill and already have one RLP15. Would...
                        12 June 2006, 23:02 Monday
                        Newbie subwoofer setup questions (Cleanbox vs BFD vs EQ)
                        by impala454
                        I have a pretty hefty bandpass box with two 10"s that I'm currently using for my sub. It's a box mostly meant for car audio competitions but right now it's filling in for HT duty until I get something else built. It has two 4Ω drivers and I can wire them however I need to (they are arranged...
                        06 May 2008, 08:18 Tuesday
                      • pudgewack
                        Help with Behringer EP2500
                        by pudgewack
                        First of all, this forum is great. This is my first post, but I have been read tons of threads and got some great ideas about some speakers that I will be building in a month or so.
                        But what I am doing now is trying to get some bass in my room. I have two Elemental Designs (car audio...
                        15 June 2006, 12:45 Thursday
                      • Inu_Yasha
                        EP2500 not getting signal?
                        by Inu_Yasha
                        I just got my EP2500 today and was trying to hook up my sub to it to test it out. To make a long story short, I used a Radio Shack 1/4" mono to rca converter and then ran a cable from my sub out. Checked the wiring and turned off the high pass filter and still no sound... Any suggestions?
                        14 August 2006, 23:16 Monday
                      • JohnL
                        EP2500 Issues
                        by JohnL
                        Hey guys, just a quick question for anyone who has some experience with the Behringer EP2500. I got mine in from DJDeals.com the other day. When I hook it up in bridge mode (switch 1, 6, & 7 on) and hook my sub up to it (on the two center connectors) , the red clip light comes on for channel 1....
                        03 February 2008, 23:42 Sunday
