Classé cp-800 output aux 1/2
  • Erik LeBeau
    • Nov 2014
    • 11
    I was wandering if I could use the two auxiliary outputs to feed the LINE IN of a B&W Zeppelin or simply active speakers for exemple.
    This way I would take advantage of the Classé high end DAC and the configurations options to direct music in the house.
  • TomScrut
    • Nov 2013
    • 532
    Yes you could, I use one of them for a zone 2 and used to use one for bi amping
    Sent from my HTC One using Tapatalk
    Music: Intel NUC -> Antelope Zodiac Platinum -> Classe CA-2300 -> B&W 802 Diamonds & 2x SVS SB13U
    • Erik LeBeau
      Classé Cp800 IOS APP "not responding"
      by Erik LeBeau
      Hello
      Grrrrr
      Maybe somebody could help me solve my problem with the Classé IOS app.
      On all my Idevices It says: Cp800 - discovered then the app is non responsive.
      Everything was working find until I changed my router for a D-Link DIR862L.
      With...
      12 November 2014, 17:29 Wednesday
    • Gianky_
      CP800 Firmware
      by Gianky_
      Dear friends,
      I'm the Italian distributor of Classé. Unfortunately since yesterday it is no longer possible to download the CP800 firmware, I have to do a restore and I don't have a copy, can you help me ? Do any of you have it? If so, can you send it to me? My email is valletta@audiogamma.i...
      15 January 2020, 11:21 Wednesday
    • wettou
      EXPERIMENT with Classé SSP-800 & B&W 802
      by wettou
      Hello I was wondering if one could use the Classé SSP-800 auxiliary channels to create the ultimate 9.1?
      Here is what I have in mind, I would like to use the Auxiliary channels to have the same signal as left and right. All speakers would be at the following
      Center 0 degree,...
      09 March 2010, 16:58 Tuesday
    • mattyw
      Jriver and CP800 remote control problem
      by mattyw
      I have recently upgraded my CP800 to Mk2 and it is working fine apart from one major problem. Having changed from USB to network connection the CP800 physical remote control no longer works correctly.
      I am using JRiver (v21) on my server to connect to the CP800 via the network connection....
      02 January 2016, 10:51 Saturday
    • 2channellover
      RTC 970 needs and aux 5.1 processor
      by 2channellover
      Newbie on this board. I was impressed with the knowledge I've seen displayed and decided to join.
      I have an old (used for 2-channel) system that I'm now trying to upgrade to home theater.
      I bought a Rotel preamp several years ago (RTC-970) and used it as the control center...
      24 January 2009, 13:22 Saturday
