I recently cleaned out the garage and found the following collecting dust.
13OV.2 elemental designs, a Behringer dsp1124p and a used hafler pro amp. So i think im going to finish this subwoofer right now. But i might need help with the tuning of the box. I started this years ago but i have no recollection on how to proceed. Below are the specs of the discontinued elemental designs driver.
Power: 600 Wrms
Qts: .28
Qes: .30
Qms: 3.3
Fs: 21 Hz
Re: 8.3
Vas: 176 L
Mms: 195 g
Bl: 21.7 T*m
SPL: 89.1 dB
Sd: 545 cm^2
Xmax: 18.3 mm
Voice Coil: 62.5 mm
thank you
Power: 600 Wrms
Qts: .28
Qes: .30
Qms: 3.3
Fs: 21 Hz
Re: 8.3
Vas: 176 L
Mms: 195 g
Bl: 21.7 T*m
SPL: 89.1 dB
Sd: 545 cm^2
Xmax: 18.3 mm
Voice Coil: 62.5 mm
thank you
. It's more of an experiment and experience since it will be my first. Anyways, i will choose the Elemental Design EQS12 subwoofer (single) and the 300w Bash amp. I don't have much wood working skills so...
