I bought an Adcom GFA-545 about a month or so ago and have been using it to power my 100 Watt DVC 12" Realistic Ported Sub. I bought the amp for a Sonosub project that has been put on hold until my 12" Shiva shows up.
Yesterday, 2 Aura Bass Shakers showed up and I finally got to check them out today. I disconnected my passive sub and hooked up the bass shakers. Time to test 'em out!
When I ran an LFE sweep, only one shaker shook (say that 5 times fast ).
So I swapped the shakers, and the problem moved to the other one.
Then I switched the inputs and the problem stayed on the left side.
This is a pretty good indication that my problem lies in the Left channel of the Adcom.
My question is about the fuses on the back of the unit. I bought this amp used, and when it arrived one there was an empty fuse hole on the back. When I tested it, it worked fine; so I figured this must be a hole to keep a spare fuse in and left it empty.
The back is setup as follows:
Fuses 1 & 2 are on the bottom left. Both are inserted and fine.
Fuse 3 is the AC fuse. It is on the right, above the power wire and it's fine.
Fuses 4 & 5 are beside each other on the bottom right. #4 (right) is present and fine. #5 (left) is missing.
Just to test it out, I moved #4 into #5's spot, and the amp did not act any different :?
So if anyone has one of these, or experience with one, could help me out, I would sure appreciate it. I looked on http://www.Adcom.com, but this unit is no longer listed .
I'm about to remove the cover and see what I can find out, so wish me luck......
Thomas.
Thomas.
