I am planning on building my first DIY subwoofer for my "future" home theater" . It's more of an experiment and experience since it will be my first. Anyways, i will choose the Elemental Design EQS12 subwoofer (single) and the 300w Bash amp. I don't have much wood working skills so i don't need a fancy box (as long as it's pleasing to the eye and won't look like a disaster sitting in a room). I would like to keep the size small and the design simple. I would like to mount the amp in the back of the box. I searched for designs using the EQS12 and i found these, unfortunately they're using dual woofers and i plan on using a single.
A dual woofer design using the same amp i plan on using:
Another dual woofer design using a different amp. I plan on mounting my amp like the way he did it:
So what sort of designs can you guys come up with?
Thanks.
Thanks.
