I have changed my mind from building the Zaph ZDT3.5 toward the Finalists for use in my living room/HT area, I think. Is there a Finalist center design?
I have the Zaph ZDT3.5 center, and have 4 of the RS180s in my mains, which replaced the blown drivers in my old Advent Reference Towers among other poor modifications. The original plan was to complete the ZDT3.5 for the R and L. I recently finished a LCR for my father and love the sound, but am anxious to try something different. The Finalist was recommended by the guys at Meniscus and I see that it's design favors close to the wall placement. So I think I'll scrap the Zaph center and start over with a set of Finalists if there is a design for the center. My mains are currently in the corners elevated 4' from the ground and within inches of the walls due to doorways, windows, couches, etc. The Finalists would need to be in this same place. Can I decrease the depth to 10" and increase the height (while maintaining volume) so that I can fit them into the same space? Although not ideal, it's the only wife-approved placement in the room.
Third, is there a surround design that would use the same tweeter (RS28f) as the Finalist and the RS180 so I can repurpose the 6 drivers I already have?
Thanks!
This will be for 7.2 in a 12x22 room with vaulted ceiling, lots of doorways and windows, poor acoustics, 2x LMS-Ultra vented for LFE, Onkyo 818
Thanks!
