I had planned to build a friend a pair of MTM's last year and the AviaTrix fit the bill. So I ordered up the components, bought the Padauk for the bafles, and of course months went by. Well he confirmed his re-location so I pushed and got them built, because I kind of had too . Since I had additional Padauk for a second set of baffle I decided to co-build a second pair (white lacquer).
Thanks to Curt and team as usual, built out the second pair today as the other's were spirited away (literally 20mins after completing them) before the finish coat had fully hardened. I went for a 7.5"x18"x 11.5"depth cabinet. Have yet to measure the final response and see if I need to tweak the XO any further. Running them in now. :T
Baffles:
Glued, Flushed +1/32" for cab paint, and Beveled:
Black Cabinets with Base Coats ready for final:
Black Lacquer Final Coat:
Crossover V1:
Baffle Clear Coat Final:
Built Out:
White Build follows same progression, though it is only a 60sheen finish, and I had a shorter piece of MDF left from the original board I re-sawed so the XO was re-arranged to fit.
Time to catch up with Dan on my RAAL Omni build, he has made great progress already, got my alumin'i'um coming next week
Baffles:
Crossover V1:
Built Out:
