Measuring Resistance issues
  • ruseriousclark
    • Feb 2007
    • 37
    Three 8 Ohm drivers in parallel should yield a resistance of 2.667 Ohms. However I just wired it up and threw on the meter and cannot get anything other than 3.4-5 Ohms as a reading.
    Busted meter or is my math just that bad?
    FYI... 3 M3N's wired in parallel
    <-- Beware of Fluffy...He is the destroyer of Worlds!
  • BOBinGA
    • 303
    Your math is correct, but 8 ohm speakers usually have a DC resistance in the 6 to 7 ohm range. This would mean a DC resistance of 2 to 2.3 ohms for three in parallel. Are you sure that one is not disconnected (or blown) and therefore not really in parallel? You would expect two in parallel to be around 3.4 ohms.
    The other possibility is that your multimeter leads have a high resistance. If you short them together, does your meter read zero or does it read something like 0.5 ohms like my cheapy meter does? 3.4 minus 0.5 is under 3 which is getting closer to what you would expect. Plus cheap meters aren't that accurate at these low resistances.
    -Bob
    -Bob
    The PEDS 2.1 mini system
    • Curt C
      • 792
      The published Re of the M3n is 6.5 ohms. 3 in parallel should measure about 2.2 ohms.
      With your measured resistance, it is possible one of the M3's is not electrically connected.
      Curt's Speaker Design Works
      • juliovideo
        Two woofers ?
        by juliovideo
        I can connect two woofers in series of 8 ohms and a resistance in parallel for 8 ohms total take. ?
        I would have that problem in this design?
        thank you.
        27 April 2009, 13:31 Monday
      • augerpro
        Resistance effects on Q
        by augerpro
        I did a little experiment to see how changing resistance changes driver Qts. I thought some of my fellow newbs might find it interesting. I used teh RS150.
        RS150 Nominal Qts= .4947
        RS150 8 Ohm in series (16 Ohm nominal) Qts= .9122
        RS150 8 ohm parallel (4...
        18 May 2007, 16:51 Friday
      • JonW
        Any recommendations for a digital volt/multi meter?
        by JonW
        Before putting together my first crossover, I should probably have a digital volt meter/digital multi meter around. To test things ahead of time and not risk frying my amp. I'm a total novice when it comes to electronics. And I can't imagine I'll use the meter for anything other than crossover testing....
        05 May 2006, 08:11 Friday
      • madclown99
        LCR Meter
        by madclown99
        Would this LCR meter be adequate for measuring parts for a XO? Specifically, for unwinding inductors to the desired value... I'm no electrician, but these items look easy to use:
        1. http://cgi.ebay.ca/LCR-RCL-INDUCTANC...2QQcategoryZ46...
        07 January 2006, 23:39 Saturday
      • niget2002
        Math Question on speakers
        by niget2002
        First, let me say this question is NOT the normal "series/parallel" type of question.
        I'm wanting to use a normal schematic test software to play around with filter design... It's more for an educational purpose than anything else.
        I also like to use linux, which...
        09 October 2007, 09:31 Tuesday
