Has anybody extensively tested Focal TC120TD5?
  • TurboFC3S
    • Nov 2006
    • 93
    I know I've seen Jon and others mention that they have some Focal TC120TD5's, waiting for testing ... and then to be applied in a design. I'm just wondering if anybody has done so. I have a pair, and am considering a couple different designs.
    One would be a 2.5 way with a couple RS180's. Crossing it over low enough to avoid the breakup nodes is the concern, can the TC120TD5 handle a 1500-1700 hz crossover point?
    Another design would be a 2 way monitor with Scanspeak 8535's ... if I get really ambitious I'd turn it into a 3 way floorstander with some 10" metal cone.
    My main questions about the TD5 are crossover related (obviously). Do completed designs work well without any sort of notch filters or 'smoothing'? And what would be the lowest recomended LR2 and LR4 crossover points?
    I'm anxious to start my next project, so any advice or links to designs using the TD5 would be appreciated - I can't find any
    • 16175
    LR4 around 2 -2.2 kHz, IMO. Very smooth, as long as you control diffraction. LR2 is quesionable because to get an LR2 response, you'd have to use less than 12 dB/octave roll off unless you have a highish crossover. Then separation distance between driver centers becomes a problem. One thing I can say about published factor Focal response curves is that for a moderate size IEC baffle, I have always gotten pretty much identical curves myself. Can't say that for many brands. It's another tweeter I'd like to try with a waveguide.
    • TurboFC3S
      • Nov 2006
      • 93
      So with a 2.2k LR4 it's probably not a good match for RS180's, right? The Scan 8535's could work well though. Good to know that the published curves are probably fairly accurate!
      I could have swore I read on here that you or somebody else tried at 1700hz LR4 with success. Am I dreaming that?
      • Paul Ebert
        • 434
        The last time I saw a fr graph for the TD5 it showed a fairly smooth output around 91 dB with a single spike of 94 or so. But, it's rated as a 94 dB tweeter. What's up with that?
        Also, E-Speakers advertises that they have these (and other Focal drivers) for sale. They're not cheap, but compared to other high-efficiency domes, they're not too bad.
        How do they compare distortion-wise?
        • Jed
          • 3621
          zalytron.com has them for $90 each. You can also see FR graph there as well. I've always been a fan of the TC120 series tweeters, though I haven't seen any distortion data.
          Jed
          • nick.h
            Which to choose: Focal or Scanspeak
            by nick.h
            I'm having trouble deciding on my new floorstanding front speakers.
            Option 1:
            Focal Utopia Be Alto Clone
            Focal Audiom TD5
            Focal 6WM
            Focal 11WX
            Option 2:
            Wilson WATT Puppy 8 Clone...
            03 February 2007, 23:02 Saturday
          • alebonau
            Club Focal
            by alebonau
            hmm doesnt seem like theres a club focal on htguide. perhaps this mini review of mine of the 1027be's might kick things off....
            Focal 1027be Hmmm, Beryllium dreaming …
            On the premise of providing a 2nd opinion for a friend plus to satisfy my own curiosity in regards this...
            08 March 2007, 17:08 Thursday
          • Paul Ebert
            D26NC55 LR2 - what frequency?
            by Paul Ebert
            A quick question.
            Does anyone happen to know, or be able to make a good guess at, what a comfortable frequency would be for the D26 with an LR2?
            10 December 2008, 13:06 Wednesday
          • Audiophiliac
            Diving in? Scanspeak/Focal?
            by Audiophiliac
            Although I work at a high end A/V shop as a custom installer and have access to Wilson, B&W, Martin Logan, Krell, Classe, VTL, etc....I also am a DIY kind of person. I mostly dabble in my car system because I dont yet own a home to start filling with gear and speakers.
            But I have...
            30 April 2006, 00:51 Sunday
          • Edgeyboy
            B&W 800 Series or JM Lab Focal
            by Edgeyboy
            I am looking to update my N804's. I had been going for a set of 803S but have been let down on those.
            There are some Focal JM Lab 927 Be's floating around on the S/H market.
            Has anyone compared the Focal's to B&W 804/803 etc ? They seem to be B&W's most direct competitor.
            27 July 2007, 23:52 Friday
