Which to choose: Focal or Scanspeak
  • nick.h
    • 171
    I'm having trouble deciding on my new floorstanding front speakers.
    Option 1:
    Focal Utopia Be Alto Clone
    Focal Audiom TD5
    Focal 6WM
    Focal 11WX
    Option 2:
    Wilson WATT Puppy 8 Clone
    Scanspeak R2904/700000
    Scanspeak 15M or 12M
    2x Scanspeak 8" Woofer (Unsure of which driver)
    21W/8555-00 Hard paper cone, low loss rubber surround, SD-1 motor 8 8 ohm
    or
    21W/8555-01 Hard paper cone, low loss rubber surround, SD-1 motor 8 8 ohm
    or
    22W/4851T00 Low loss linear suspension, SD-1 motor system, hard paper cone 8 4 ohm
    or
    22W/8851T00 Low loss linear suspension, SD-1 motor system, hard paper cone 8 8 ohm
    or
    22W/8857T00 Low loss linear suspension, SD-1 motor system, aluminium cone
    Keeping in mind these are not exact clones, but close.
    Designed to be used with a Bryston SP2 and 6B SST
    What you guys think?
  • TurboFC3S
    • Nov 2006
    • 93
    How about you design, tweak, and perfect both clones ... give us the plans ... and then decide which one you like best
    • Mazeroth
      • 422
      I'd build a speaker without a box (dipole) :T
      • Rock789
        • Feb 2007
        where do you purchase the focal drivers/tweeter?
          • 10931
          Some places like Zalytron have a limited stock of Focal drivers.
          • jdybnis
            • 399
            I think you'll get much better bang for you buck with the ScanSpeak drivers.
            -Josh
            • cotdt
              • 393
              ScanSpeak and bang-for-buck in the same sentence? what is this world coming to...
              • nick.h
                • 171
                Costings are the same
                • jimluu
                  • 53
                  I've listened to both focal and wilson speakers several times, and in general I think the focals sound much better than the wilsons. If possible, I'd clone the focals. That said, I bought some 6w woofers from zalytron, and frankly I don't think they are worth the price at $90 each. The build quality is OK, but not great. I gave up trying to clone the focals, and will probably use the 6w as mids in a dipole project later on.
                  • Rock789
                    • Feb 2007
                    is it possible to purchase the same drivers found in the present focal line, or only older models?
                    • TacoD
                      • 1078
                      Only older models, the berylium tweeter is available in the car series from Focal.
                      But I would not clone those speakers, build something from Jon instead.
