DIY speakers or amp first
  • BDixon
    • 16
    I wasn't sure where this should go but I figured this section would have the most people who have dealt with this. What route would/did most folks take? Did you build your speakers first then upgrade to a better amp/receiver or get the amp first? Or was a more powerfull not even needed?
    Right now I've got an old Sony 30ES powering M&K S-125 L/R/C and SS-150 sourrounds and have the chance to get a Outlaw 750 amp locally. I was planning to replace my receiver next year(with something like an HK 435).
    I was planning to build some mains and center soon but this might set that back a couple months. It seems some of the speaker designs might be a little difficult for a regular receiver so I'm wondering if getting a decent amp first would be the route to go.
    Thanks again,
    Brad
  • TacoD
    • 1080
    In my opinion are the loudspeakers the most important part of the audio chain. My experience is that changing speakers bring more changes than switching amplifiers/ cables/ etc..
    just my $0.02
      IMHO, play with room setup first. Before you do anything else. This may include more dramatic changes that you can not make permanent (like taking the side couch out, for example).
      Identify what is lacking, what you hope to achieve.
      That should tell you more clearly what direction to take.
      • BDixon
        • 16
        I don't disagree. But what I'm not sure of is if my current receiver will handle the loads some of these DIY designs will place on it. That's the primary problem, build the speakers first and hope my receiver handles it fine or get an amp that will handle then build the speakers.
        I just figured some of the DIY guys have been thru this before and wondered what route they took and if they'd do it the same way again.
        Brad
        • AndrewM
          • Oct 2000
          • 447
          I did speakers first way, WAY back when, hooked up to a Denon reciever. Then added an amp (didn't make that much of a difference until the volume level went past my usualy listening level), the bigger difference happened when I pulled the reciever out and put in a good pre-pro.
          I'd do it the same way again if I were in that position, and speaker upgrades are usually a good "bang for the buck" upgrade when it comes to doing an upgrade.
          Andrew
          • John Holmes
            Got a new amp! (Emotiva LPA-1)
            by John Holmes
            "Friday the 13th", turned out the be a very good day for me! It was the day that my 63lb, 19 inches deep, LPA-1 amp arrived. The UPS guy was not a happy camper (I live in a second floor apt). He called me on the phone while sitting outside of my home to make sure I was there. :lol:
            16 July 2007, 15:25 Monday
          • tran_tuan_duc
            B&W 804s
            by tran_tuan_duc
            Hi room,I am using DENON 2000AE to drive the B&W 703s,now I want to upgrade my system,my budget is about 2000$,I don't know which one to upgade first,amp or speaker,my tips is:
            Upgrade 703s to 804s
            Upgrade DENON 2000AE to Accuphse E 406v,407 or 408
            I only can afford...
            07 July 2006, 01:19 Friday
          • kemosabe
            Rotel + M&K S150/SS150/MX350 speakers?
            by kemosabe
            It's been suggested that I partner the RSP1068/RMB1095 combo with M&K S150/SS150/MX350 speaker combo. Does anybody have any comments about this suggestion?
            For a 7.1 setup do I need another amp given the 1095 is only 5 channel?
            I'm keen on the speakers, and understand...
            11 November 2005, 14:07 Friday
          • Jmacs_Naim
            General assistance asked for re integrating 2 channel & AV/HT
            by Jmacs_Naim
            Hello All
            I have been a 'lurker' here for a while, and after getting a feel for the place, which BTW seems pretty friendly, and quite knowledgeable, thought i would register as I have something of an ongoing quest to finish my AV/HT journey which I started some 2 yrs ago, and would appreciate...
            26 May 2004, 05:30 Wednesday
          • hotwheels
            B&W Center for Rogers LS7?
            by hotwheels
            After a long time I have decided to try to work around what I have always thought was a living room that was just not well suited to sound or HT. My spouse has wanted HT for a few years, so we bought a 37" LCD and she brought home a Rotel 1056 the other day. We hooked it up to L&R...
            31 July 2005, 20:27 Sunday
