CD burner problem
    • 16478
    CD burner problem
    I have a HP 9100 8X CDRW burner on my Win2K machine running EZCD4 using an overclocked celeon CPU (running at 1000hz) with ATA100 7200 RPM quantum HHD. My problem is that even if I am copying files from the hard drive to the burner it won't burn faster then 4X w/o getting a buffer under run. I'm wondering why I can't supply data fast enough to burn at 8X when the hard ware I've got should do it?
    Joey what were you able to get with your old burner?
  • Kevin P
    • 10812
    Does the burner share an IDE interface with another device? What is it? Is it in use when you're burning CDs?
    Try switching it to the other interface, if possible. Or switching master and slave.
    Are you running any other software while burning CDs? One thing I've learned is "never try to launch IE while a CD is burning". 'Course, if IE is already running there's no problem. But loading it takes long enough to cause a buffer underrun at 8x.
    On my PC, the IDEs are set up as follows (I think):
    Primary IDE: Master-hard drive, Slave-DVD-ROM
    Secondary IDE: Master-CD burner, Slave-8GB Travan tape drive
    It probably helps that the CD burner has the secondary IDE to itself when burning CDs (I only use the tape drive for backups).
    Putting the device you're burning from (hard drive or CD-ROM) and the burner on separate IDEs certainly doesn't hurt matters either.
    KJP
    P.S. Also check to see if there's Win2K driver updates or patches for EZCD4. I seem to recall that it needed to be patched to work properly in Win2K.
    My HT Site
      • 16478
      Kevin its the seconadary master and I don't have anything else running in the back ground. I'll check into the patches though thanks for the idea.
        Check here for assistance
        CD-Recordable FAQ, including CD-R and CD-RW, updated monthly
          • 16478
          thanks thomas I think I found one problem in that my RAM wasn't performing very well due to a couple of settings in the BIOS. I've got those tweaked now so things might have improved at bit but I havne't tried it yet
