adding hard drive catch 22
    • 27460
    I was going to put a second 500 gb drive in my new little HP Vista 64 bit machine, well I got the drive physically inserted, however, when trying to get power to it, I ran into a problem. My drive is SATA, and there are no additional SATA power connections. Is there such a thing as standard power connector to SATA power connector adapter?
    My other choice is adding a more powerful power supply, which I may have to do anyway to have enough power for the drive. I question if the 300 watt power supply has enough juice to handle two hard drives. (Phenom 9550 chip with 2.2 gh quad core design, 500 gb HD, CD, that's it other than 6 gig ram, Anyone?
    I'm bummed, I really wanted a second HD, but no of no way to power one. If I go standard drive, then it's IDE, maybe it has IDE support, I'd have to see, but I know I have spare SATA inputs.
  • littlesaint
    • 824
    SATA power adapters exist and work fine.
    http://www.newegg.com/Product/Produc...dapter&x=0&y=0
    300W should be OK, but just like audio power, you can never have too much. :T
    Santino
    • Kevin P
      • 10812
      Does the machine already have 2 SATA drives? Usually power supplies with SATA connectors have at least 2 already. If not, Littlesaint is right, Molex-SATA adapters are available, you can get them online or at the local 'puter shop or Best Buy.
      The motherboard has an open SATA connector for your drive, right? Make sure it does. As you probably already know, there's 2 connectors on the drive, one for data and one for power.
        • 27460
        That's exactly what I need, not sure if Best Buy has it or not, but I can check them. If not, I'll order it.
        Well, there are 4 SATA connections on mobo, I already connected a cable to it when I started connecting the drive, but then realized, I had no SATA compatible power connector. I got plenty of old style bundled up, quite a quandry with a 500 gig SATA drive in my hand.
        Thanks guys! I'd like to just use the 300 watt supply, it's so quite, and that's sort of nice compared to my jet engine I am used to on the old dual PC with dual fans and power supply running...
          Circuit city used to have them haha. Best-buy might if they don't though check a radio shack possibly something like Staples might as well. Radioshack is kind of hit or miss cause some of them carry them some don't.
            • 27460
            I was able to run down to the local Electronics supply store today after a quick phone call to verify they had them. :-) So, it took me all of 5 minutes to install the drive after I got home, it's formatting now.
            So, that worked out great, thanks for letting me know that the elusive adapter did exist.
            Oh and Kevin, the original comment about two Sata connectors, yes, it did have two, and one is used by Lightscribe DVD drive and the other the hard drive. So, that's one two strikes and I was out. Being a basic power supply, you can't have everything I guess. But the 4.00 adapter tax and all, worked like a champ. :T
              My TIVO Upgrade - It's A Snap!!!
              by David Meek
              I've been kicking around the idea of adding more capacity to my 2-year-old TIVO for several months. I finally broke down and ordered an upgrade kit for my HDR31203 model from Weaknees. At $179 including shipping, I got a 120 Gbyte hard drive, a mounting bracket, the necessary nuts 'n bolts and a Torx...
              08 September 2003, 22:00 Monday
            • kpodolski
              CDP-XXX / IDE to SATA converter
              by kpodolski
              Looks like someone is offering a conversion kit for Classe CDP players.
              https://www.ebay.com/itm/Classe-CDP-...53.m1438.l2649
              Since the Teac DV28SL drive...
              01 February 2019, 11:44 Friday
            • aarsoe
              Anyone with a CDP unit that have had the drive replaced?
              by aarsoe
              If you are the owner of any of the following CDP models: 102, 202, 300 or 502 and you have had your drive replaced then I hope you can help me by answering the following questions.
              1. Do you happen to know what the brand/model number of the parallel IDE to SATA adapter that was used...
              25 May 2017, 21:18 Thursday
              DirecTV DVR Sata Port
              by Lex
              Has anayone used the Sata port to add an external hard drive? It does not enable dual boot drive, the external sata overrides use of internal drive, so you can't access what is on the normal drive when using the sata connected drive. But you can enable much more space of course this way, that is...
              17 July 2012, 06:28 Tuesday
              1 Terabyte DirecTV Add on drive
              by Lex
              I just got my 1 Terabyte add on hard drive (external) from WD with an external e-sata port. I wasn 't sure if one was Sata and one was E-sata, and I might need a cable with one type end on each end. But after ordering that cable, it wound up being the cable with like ends. e-sata I think, that worked....
              04 December 2012, 11:42 Tuesday
