Diy ir receiver that would work with xantech connecting block?
  • silvercans
    • 39
    Anyone know how to build your own?
    http://lnx.manoweb.com/lirc/
      Ummm... any reason for DIY instead of using Xantech's receiver? Mine works great. Not free, but not overly expensive.
      • MaxTimeOff
        Setting up my Yamaha 2500 receiver in my HT.
        by MaxTimeOff
        I have a Yamaha 2500 receiver in my 5.1 HT. I just turned it on and I have sound out of the fronts, center and base. No sound out of the rears however. I think the volume is just turned down on this channel.
        The way I have my system set up, I do not have any video pumping through the...
        26 February 2005, 16:16 Saturday
      • AwArEnEsS
        Recording to computer while listening from receiver+speakers?
        by AwArEnEsS
        While I am listening to the radio(on internet) broadcasting,I want to record the broadcasting as files on computer.Receiver is connected via Digital Optical Out to the computer.The problem is,when the audio setting on computer is set as "Realtek Digital Output",I am not able to record the...
        17 January 2010, 16:57 Sunday
      • Bent
        Xantech IR gear (or the like), Andrew?
        by Bent
        Greetings again,
        I just picked up a Xantech Hidden Link IR kit, and it works flawlessly...
        However one peice of perfection yet evades me, I need to know what is done when you require a AV receiver that has an IR input jack to connect to a Xantech connecting block (IR manifold)?...
        20 October 2003, 22:30 Monday
      • cameronl
        Xantech with C2
        by cameronl
        hi all, I have some questions regarding xantech that I am hoping someone can help with
        1. can I plug a xantech ir receiver directly into the main ir input on my c2?
        2. can I plug a 3.5mm jack (mono?) between the zone 2 ir input on my c2 and a xantech CB20. I want to...
        12 August 2008, 06:05 Tuesday
      • keiron99
        RSP 1066 and Xantech IR repeater
        by keiron99
        I'm not having any luck getting my Xantech IR repeaters and emitters to work with my RSP1066. I currently have an entire Xantech distribution system and everything works fine. When plugged into the 1066, the receiver doesn't even flash to indicate a signal is being received. The Rotel manual names Xantech...
        18 March 2004, 12:32 Thursday
