I have a Yamaha 2500 receiver in my 5.1 HT. I just turned it on and I have sound out of the fronts, center and base. No sound out of the rears however. I think the volume is just turned down on this channel.
The way I have my system set up, I do not have any video pumping through the receiver, just audio. For video, I go direct from the Sat box to the plasma and direct from the DVD player to the plasma.
I want to perform the auto setup procedure to balance everything, and hopfully get the rears working. Seems easy enough. In the manual it shows a menu display that you follow for the setup. Question is, will this menu show up on the receiver, or do I need to have a monitor connected to the receiver to see this setup menu? If so, how should I connect the receiver to Plasma? I never anticipated connecting the receiver to the plasma.
