problem with 1024x768 proj, dvi input, and hd dvd, help please?
  • jig
    • Dec 2003
    • 8
    i'd like to know how prevalent my current problem is.
    i have a hidef receiver/dvdplayer (the LG lst-3510A) with an hdcp dvi output, and a projector with 1024x768 native resolution and an hdcp dvi input.
    my problem is that the 720p output of the receiver is chopped off on the right hand side by the projector (1280 vs 1024).
    should i expect the projector to be able to scale the dvi input to fit, or is this a common problem? i know that the projector seems to scale dvi input from a pc automatically when it is beyond the native resolution... so i'm guessing there is some kind of hdcp handshake problem.
    by entering a special menu, my Bravo dvd player (also has dvi out) can scale the image so that the entire scene is shown, but so far i can't find, and don't expect to find a similar menu in the LG.
    could this all be caused by a bad or incorrect standard dvi cable? i use the same cable with the pc and the two dvd players/receiver.
    the projector is the proxima dp8000, the dvd/hd receiver combo is the LG lst-3510A, and the bravo dvd player is the D1.
    i guess i wonder why this projector has hdcp dvi in if it can't reproduce a regular hidef signal.
    if this is a common problem with 1024x768 projectors and HD receivers/dvd players, especially those with hdcp dvi inputs, then if someone can just chime in, i'll just leave it at that and move on.
    Further info: the LG is a QAM capable receiver, and the HD signals it brings in over cable look outstanding when using the d-sub RGB (analogue) path, which the projector has decided it is able to scale to fit on the screen. But the LG follows the rules as to dvd upscaling and won't produce a 720p or 1080i signal over any line except the HDCP dvi input. arg.
    thanks for any help, questions are appreciated as well. anything to help me decide if there is anything i can try. i guess the most important thing to know is if this has or has not happened to anyone else with a 1024x768 proj.
    -jig
  • Brandon B
    • Jun 2001
    • 2189
    What happens when you set the Bravo to its standard 720p DVI ouput instead of using a custom resolution? Same thing?
    BB
    • jig
      • Dec 2003
      • 8
      yeah, same thing.
      • psrontom
        Non-HDCP FP, HDCP DVD player - how to?
        by psrontom
        I just got my SE 20HD projector, and am in the hunt for my new DVD player with DVI/HDCP/HDMI output. I'd rather not go Bravo D1 because of its poor reliability issues... and it's the only non-HDCP player I know of.
        To my knowledge, one device can strip / decode the HDCP from the DVI data,...
        22 October 2004, 18:46 Friday
      • Doug S
        Computer DVI-D out/Projector
        by Doug S
        Hello Again...I Just got off the phone with a salesman about an Infocus 4805 and when talking to him about hooking this up to my DVI-D out On my Gateway Multi-media system he said this may not work as projector won't recognize this output because it is computer output something about HDCP. Does anyone...
        13 December 2004, 21:10 Monday
      • Doug S
        HTPC DVI out to Projector Issue
        by Doug S
        I need some help here guys....i have a Infocus 4805 that I had hooked to my vga port out of my pc{worked fine} but want to keep my existing monitor hooked into that port...so thought I would hook projector...
        23 December 2004, 17:29 Thursday
      • mwgwin
        Connecting PC through AV receiver (DVI/HDMI)
        by mwgwin
        Has anyone had trouble connecting their PC through their receiver?
        Here is my setup
        PC with ATI Radeon 9600 Pro video card with DVI and VGA outputs.
        Yamaha RX-V1600 with 2 HDMI inputs and 1 HDMI output
        Dell 5100MP projector with about one of each type of input imaginable....
        08 December 2005, 10:58 Thursday
      • Frank T.
        DVI doesn't equal DVI!
        by Frank T.
        What a drag: The moment you think you are able to match a brand name DVI player with a front projector with the much required "HDCP authorized" DVI input, more problems arrive:
        Some DVI output DVD players prefer the companionship of certain front projectors. Forget 'Plug &...
        07 November 2003, 20:50 Friday
