xbox problems on plv z1
  • Jurgen
    • Jul 2003
    • 73
    Hi all,
    I own a sanyo plvz1 and an xbox. Both give me great joy but combined I'me having some difficulties with them. When I hook up the xbox to the pj via composite and s video the picture "stutters" a bit and the primary colours are shaky.
    The gameqube does not present a problem and neither does my dvd player(via component).
    Has anyone had the same experience? Help is greatly appreciated!
    Jurgen.
  • cofn
    • Dec 2002
    • 71
    I don't have a PLV-Z1, but I do have the Matinee 1HD which is the identical unit just by Studio Expressions. I have my Xbox hooked up via components and have had no problems at all.
    Did you go into the dashboard and enable 480P, 720P and 1080I? I did notice some weirdness on my part until I did. The screen would be cut in half and flickering until I made the change. But everything is fine now.
    • Jurgen
      • Jul 2003
      • 73
      Thanks for your input!
      I am using a pal machine and therefore have not connected the Xbox with component cables(not really a standard here in Europe yet)and that also excludes the use of progressive scan(for now).
      I do suspect however, that this feature is in someway interfering with the current image via Svideo. I think I will try to get my hands on a component cable for xbox(probably by import)and experiment further.
      Is there a degradation in picture quality when you use the component switching feaure of a homecinema amp(in my case the Rotel rsx1055)instead of a direct connection?
      Jurgen
      • Dave D
        Xbox: S-Video AND Component Outs?
        by Dave D
        Hi all,
        Does anyone know of a way to get S-video AND component video signals out of an Xbox? I know you can purchase S-video OR component video cables, but I'm not aware of anything that does both concurrently.
        Unfortunately, I need S-video for the TV and component for...
        07 January 2006, 19:32 Saturday
      • Jurgen
        your settings on plvz1?
        by Jurgen
        Since quite a few of you own the Sanyo plv z1(or the 1hd), I am curious how you calibrated them and in what kind of conditions. Maybe I ask a lot and maybe it is a bit foolish since there are so many variables involved, but perhaps we can help each other out in obtaining an optimal...
        06 November 2003, 06:14 Thursday
      • Trevor Schell
        Sanyo PLV-Z2 & Studio Experience Matinee 2HD Discussion Thread
        by Trevor Schell
        This thread will be dedicated to the discussions of the new Sanyo PLV-Z2
        and clone, which is the Boxlight Studio Experience Matinee 2HD.
        Here are the specs of the two units.
        PLV-Z2 /Matinee 2HD
        * Technology: Polysilicon
        * Resolution: 1280x720...
        12 February 2004, 15:13 Thursday
      • JoeHard
        Help with component video and 1066
        by JoeHard
        I want to connect a dvd player, Xbox, and cable box to my Pioneer tv using component video . The tv has two component ins. I hooked the cable box directly to component input 1 on the tv, and and the component out of the 1066 to the tv's component input 2. Then I connected the Xbox and dvd player to...
        23 January 2005, 20:32 Sunday
      • cdika17
        RSP-1570 AND XBOX 360 elite ISSUES
        by cdika17
        I have mentioned this on another thread but it's lacking feedback, so i fiugred i'd start my own thread.
        When i have my xbox360 hooked up, the hdmi feed drops out, then in and out. Signal loss then comes back for a sec, i shut everything off, did factory default, still doing it, any suggestions?...
        25 September 2009, 14:34 Friday
