I cannot get a signal when connecting my Scientific Atlanta 8300HD DVR to my WS65713 via a HDMI/DVI cable. I created a new devise with the following settings: Cable Box, SCI_Atlanta (defaults to model 8600 even though I have a 8300HD, RF check box unchecked, TV imput MONLINK (w/ video and audio checked) and saved it. When I change to that new devise I do not get a signal. Any help would be appreciated!
MITS WS65713 DVI connection help!
My guess is it's probably the Sci-Atlanta box. I've heard of many people having problems with them over DVI. Have you any way to check another DVI or HDMI source and different cable? At least that would tell you if it is/isn't the TV. Otherwise I suggest you contact your SP that gave tou the box
Jason- Bottom
by mjamesI just got this 5.1 Samsung HT-P38 package and have a Scientific Atlanta 8300HD cable box and a Samsung LTP227W 22" LCD HDTV. My problem is I can't get sound from the cable box to go through my 5.1 speakers when watching TV. How would I do this?
My TV has component 1 and 2 and L/R...-
by psychdocHi all,
I'm guessing that someone in this forum has dealt with this problem so I am hoping for an easy solution (don't work harder, work smarter :W ).
I have a buzzing in my system (lot of this going around it seems). I have already isolated the difficulty to the coax cable connection....-
Channel: Club Halo/Parasound
by JonMarshThis player is being brought in from the folks who import the Momitsu, but it's not a Momitsu.... and it has Faroudja DCDi de-interlacing. The lack of the Faroudja processor in many upscaling DVD players is a sore point, IMO.
OPDV-971H DVI/MPEG/DIVX/XviD DVD player
by draganmA few people have inquired on this board in the past about being able to input a DVI signal into their CRT projector. For about a year now, a guy named Moome in Hong Kong has been manufacturing cards that plug directly into the electrohome Marquee, Sony, Barco, and NEC CRT projectors. The card accpets... -
by juneHello All,
Comcast has a new HDTV cable box verson 3 with a HDMI output. My sony HDTV only has a DVI input. The cable installer brought this new box with a HDMI to DVI cable. This didn't work properly. No picture after a hour or so of viewing. We had to switch back to component output...-
- Loading...
- No more items.
