30" Samsung TXN3075 HD problem
  • PSUfan
    • 80
    I just received the Scientific American 8300HD box from Adelphia. I have it setup to automatically detect the best picture settings(480i, 1080i, etc.). Well tuning in to a HD channel my tv went all white. All the channels are white now with the exception of the info bar along the bottom of the tv. To eliminate the cable box as the problem I switched to my dvd player on component video 2 and all i have is a green screen with fuzzies on it when I press play.
    1) I'm assuming this is a problem the the tuner on the television;
    2) Can it be fixed?
    Also, I hooked up the cable box to the tv on AV1 and the picture is fine.
    Shane
  • PSUfan
    • 80
    fixed.
    thanks
    • madmac
      Samsung laser printer problems!!
      by madmac
      Hey all,
      I have a Netbook and decided to get a simple Samsung black and white Laser printer to print stuff off of it. Problem is, I can't get the damn driver to load into the Netbook. I have a portable dvd drive that I can hook up to the Netbook but it get's about 2/3rd's of the way through...
      09 November 2012, 15:25 Friday
    • mattstacey
      Rotel 1066 component video setup problem
      by mattstacey
      Hi guys,
      I just replaced my Denon 3802 with a Rotel 1066 yesterday, hooked up to a Rotel 1075 amp. I haven't had much of a chance to listen to it yet but so far it sounds awesome.
      I have a problem with my video connections though. I had no problems with the Denon 3802 so...
      18 October 2003, 23:39 Saturday
    • Bing Fung
      Toshiba HX93 RPTV Vertical White Line Fix
      by Bing Fung
      I finally made the time to call in Tech repairs for the Vertical white line problem that plauges the Toshiba RPTV.
      The white line problem is a faint vertical white line at about centre of the screen. It is approximately 10-15mm thick and runs the entire length of the screen. It is...
      31 March 2005, 19:25 Thursday
    • wrekkah
      1056 video processing problem?
      by wrekkah
      I'm in the process of troubleshooting an intermitent problem with the video chain of my HT. I have an older Hughes satellite box. I send the signal to the 1056 via s-video. From the 1056 I send video signal to my TV (Sammy HLP 4674) via component and s-video. When I'm viewing the component signal, the...
      15 September 2005, 14:31 Thursday
      Help with HDMI audio problem please
      by bigburner
      A friend has asked me to help him with an audio problem that is outside my area of expertise.
      My friend has recently upgraded his plasma to a 1080p Samsung. Immediately he started experiencing audio problems when playing DVDs on his OPPO 981. The problems are skipping and volume fade....
      14 September 2008, 02:10 Sunday
